Date: 07-05-26  Time: 19:32 pm
Author Topic: Dodgy fuel gauge  (Read 26448 times)
2old2boogie
Dodgy fuel gauge
« on: 18 January 2012, 03:46:55 pm »
The fuel gauge on my Fazer 600 shows full all the time! Is this a known fault on this bike? If so what is the cure?
Silverdream
Re: Dodgy fuel gauge
« Reply #1 on: 18 January 2012, 11:20:24 pm »
 :eek once you have filled up .. you need to ride a few miles... :rolleyes
Unless you have one of those miracle bikes that runs on air....  :rollin
Wish mine was full all the time... im usually rooting around my deep pockets for the last pennies for some petrol
Seriously though... in the petrol tank.. stuck sender unit.. maybe give it wiggle or check the wires coming out of the bottom of the tank and make sure they are still connected to the loom...???
Fazerjon
« Reply #2 on: 19 January 2012, 06:57:35 am »
Could also be a wire shorting to earth, check your wiring from the tank sender all the way back.
2old2boogie
« Reply #3 on: 19 January 2012, 03:51:37 pm »
Thanks for the feedback lads. I will bite on the bullet then and get the multitester out. Thought it was best to check if there was a known fault on these models that may have saved a lot of hassle troubleshooting  ;)
Jacko
« Reply #4 on: 20 January 2012, 07:28:28 pm »
Interesting, when mines nearly empty the gauge goes up to full sometimes, will check wiring also.
Fazerjon
« Reply #5 on: 25 January 2012, 01:11:17 pm »
Did you sort out your fuel gauge? If so what did you find?  :rolleyes
2old2boogie
« Reply #6 on: 26 January 2012, 03:43:45 pm »
No I have not got round to it yet. I'll post on here when I do, probably over the weekend  :rolleyes
helloindustries
« Reply #7 on: 12 December 2014, 03:49:56 pm »
Looks like i'll have to do similar.
Mine either shows below empty, above full or half when it's actually full.
Recently had the fuel warning light decide not to warn me. Had to have the bike picked up this morning which was embarrassing...
reddave101
« Reply #8 on: 14 December 2014, 01:42:44 pm »
had same problem, but thankfully it is sorted. 1 time it would show full and the next it would show empty even after I fill up. What I found after stripping a few things off was that the terminals under the tank for the sender unit were a bit green and the rubber cover was twisted. Dismantled the tank, cleaned the terminals, untwisted the rubber cover, put a piece of sponge on the frame where the fuel pump is as when the tank is lowered the terminals maybe touching and earthing against the crossbar under the tank. Did all this and since then had accurate readings on my gauge.  :)
helloindustries
« Reply #9 on: 14 December 2014, 02:01:36 pm »
I will also try this.
chris.turton
« Reply #10 on: 15 December 2014, 08:50:29 am »
Cheers, I'll have a look at this myself. It never really occured to me that a fuel gauge on a bike could be reliable so I just try to remember to fill up at around 130 miles. It would be nice to have it working properly though
loadeddice
« Reply #11 on: 21 December 2014, 11:03:41 pm »
Interesting....my fuel gauge has similar 'episodes'. I began restoration back in 2011 ensuring all terminals were cleaned & greased, so I'd be surprised if mine has become corroded again in that time. However, I intend to finish the resto' over this winter & will check again.
Could it possibly be the tank sensor/sender...?
« Reply #12 on: 30 December 2014, 10:54:54 pm »
Had a similar problem recently and fixed it over Christmas, forgot to take a few pictures.
As most may know it uses a potentiometer which changes resistance as the level of fuel drops. It has a small levers which rotate across a resistive track to change the resistance. Sometimes the tracks wear or the lever wears in the holder.
I removed the sender unit and the bar which holds the float felt like it had to much play on the potentiometer side. This is held in place with a spring washer with a washer under it.
Using a pliers I pushed the spring washer down more to tighten it up and it appears to have resolved the problem.
« Reply #13 on: 31 December 2014, 03:33:34 pm »
Spring washer with a washer,resistive track,potentiometer, ????? Eh
 shame you forgot to take pictures
« Reply #14 on: 04 January 2015, 10:24:51 pm »
If you remove the sender the spring washer and washer are fairly obvious. If I get time this week I will take it off again and take a picture
Paulfzs
« Reply #15 on: 05 January 2015, 05:19:34 am »
Will have to do this on mine, shame ive just brimmed the tank.
Freza
« Reply #16 on: 25 April 2015, 01:53:34 pm »
I started having problems with my fuel gauge yesterday as well. The tank is full but the gauge jumps all around, showing half-full, then empty, then reserve light goes on, then off, etc.
I sprayed some WD40 on contacts below the tank, but it didn't help.
What should I try next? I didn't understand a word here (sorry, eng is not my native language):
midden
« Reply #17 on: 25 April 2015, 02:11:15 pm »
 :eek  Thought I was king of Procrastination  :evil
« Reply #18 on: 25 April 2015, 03:20:21 pm »
See picture
Freza
« Reply #19 on: 25 April 2015, 04:44:15 pm »
Thanks, will try tomorrow!
infiniteloop
« Reply #20 on: 25 April 2015, 05:09:22 pm »
Need to check mine out soon….often my fuel gauge shows full at the same time the reserve light is on..!
positron
« Reply #21 on: 25 April 2015, 05:32:13 pm »
Just to add to the variety, my fuel gauge only works when I am doing 5k+ RPM. On idle or low speading, it keeps moving down and down and eventually low fuel warning light comes up, but as soon as I pick up decent speed, needle starts creeping back up again and when it works the reading is correct. Never bothered me too much as I always (and need to) fill up every other day.
Freza
« Reply #22 on: 26 April 2015, 02:59:05 pm »
You were right.
One of these needles wasn't touching the contact board, due to loose washer.
I fixed it now, but more importantly, I think I know what caused it to get loose.
The bar which holds the float is on easy spot to get hit by fuel pistol while refueling, so, if you insert the pistol too low, you'll probably hit it and step by step cause further loosening of the washer.
I advise caution when inserting the pistol to avoid that...
« Reply #23 on: 26 April 2015, 07:05:42 pm »
 :thumbup
loadeddice
« Reply #24 on: 13 May 2015, 10:29:53 pm »
Here we go again......I've finished my rebuild at last & during the latter stages of the process I did indeed, address my fuel gauge/sender issues. However, despite all advice applied to my sender/wires, my fault persists.
Is it possible to install a picture of my Fazer here anyplace..?
