Date: 07-05-26  Time: 19:32 pm
Author Topic: Dodgy fuel gauge  (Read 26436 times)
sinto
Re: Dodgy fuel gauge
« Reply #25 on: 13 May 2015, 11:13:04 pm »
Here we go again......I've finished my rebuild at last & during the latter stages of the process I did indeed, address my fuel gauge/sender issues. However, despite all advice applied to my sender/wires, my fault persists.
Is it possible to install a picture of my Fazer here anyplace..?
Posting a pic here's easy....
In the same way you replied to the message in the thread....
Go down a wee bit it says Additional Options, press that and then Add attachment then choose file, that's it, post your pic that way.
Oh that's providing your using a phone, think on computer it's easier :)
edit: it's just the same way!
loadeddice
« Reply #26 on: 14 May 2015, 10:39:43 pm »
Excellent, thank you. Pic should emerge...............?
sinto
« Reply #27 on: 14 May 2015, 10:43:10 pm »
Your welcome.
You can now post like that in any thread your on, easy eh?
Yes both pics showing fine :)
Nice colour scheme :)
rhinoeli
« Reply #28 on: 15 May 2015, 08:15:04 am »
That is a very clean bike.
What did you do to the swingarm? is it painted?
sinto
« Reply #29 on: 15 May 2015, 06:00:59 pm »
I was wondering that too, looks a nice and clean job but also noticed the notches at the rear bolt are not visible, don't think that's a good idea :thumbdown
loadeddice
« Reply #30 on: 15 May 2015, 11:41:19 pm »
Swingarm painted, re-anodising a bit too expensive! I try to do all the work to minimise costs. Plating however, is not within my capabillity.
Yes, the alignment marks are there for me to see. The trick is to file the grooves a little prior to paint application.
Paulfzs
« Reply #31 on: 29 May 2015, 06:08:36 pm »
why do i have to be different...
took mine apart and was greeted with this.
loadeddice
« Reply #32 on: 05 June 2015, 09:57:57 pm »
Well, this seems a continuous story! I've now addressed the wiring/plug/socket, tightening the washer, ensuring the cover fits over correctly.....& still my guage reads full when it pleases.
Grayman
« Reply #33 on: 23 October 2015, 11:03:36 am »
I've had this issue with my fuel gauge this week, after removing the gauge and testing and it all checking out ok  I noticed one of the terminals on the fuel sender had been rubbing on the frame causing the sender to earth out and the gauge to read full. After finding this i repaired the insulation and put some foam on the frame to prevent it happening again.
loadeddice
« Reply #34 on: 24 October 2015, 11:14:10 am »
Well, I'm pleased to see this issue remains constantly in progress. I have tried every cure mentioned herein, without success. In fact, over tightening the small washer on the sender appeared to produce a very slow gauge reading response. So, if a 'permanent' cure is found, I'm still anxious to read more.......
loadeddice
« Reply #35 on: 07 September 2016, 09:50:48 am »
Hi all. I've been around the block on this fuel gauge thingy, new sender & all! I've yet to acquire another set of clox to try however. I now notice that when cold the gauge reads fine. When hot (after a few miles only) the gauge reads full. Would this be the fuel gauge? Anyone tried this route?
