Date: 26-04-26  Time: 06:55 am
Author Topic: weave /wobble  (Read 12683 times)
Re: weave /wobble
« Reply #25 on: 19 May 2014, 09:21:01 pm »
Cheers UNFAZED......dont know whats happened to MR NOG.....parhaps hes lost his bearings   :rollin
Re: weave /wobble
« Reply #26 on: 19 May 2014, 10:00:41 pm »
Maybe he is outside looking for the spider to check the WEB site :lol
Re: weave /wobble
« Reply #27 on: 19 May 2014, 11:12:14 pm »
Oh how i chortled :rollin :rollin :rollin
Sorry red.....i had to watch that bear gryls  survival thing & then things happened....n stuff............unfazed was it you that recommended me them in the first place or did you just do a search?.......im sure it was you...if it was then sorry for not remembering......bad drills really aint it.
But has red saved any money....thats what counts.......fast bike discount
Re: weave /wobble
« Reply #28 on: 19 May 2014, 11:52:30 pm »
Yeah, it was me, but it is ok, I can handle it.
Re: weave /wobble
« Reply #29 on: 20 May 2014, 06:48:08 am »
no probs MR NOG.......fazer thou not shown on web site,have emailed them,looking at the other yam bearings its looks like there will be a small saving.£4 ish for both....if i dont get a reply by tonight i`ll order from wemoto,they have them in stock and are quick to deliver  ;)
nickodemon
Re: weave /wobble
« Reply #30 on: 20 May 2014, 10:20:49 am »
This is the one
http://shop.marksman-ind.com/motorcycle-bearings-bikebearingscouk-2-c.asp
Great to deal with
I used them for my r1 front end bearings. Ask for mark. Very helpful guy and they arrived the next day.
Re: weave /wobble
« Reply #31 on: 21 May 2014, 05:57:50 pm »
mmmmmmmm.....look what i've got...
Re: weave /wobble
« Reply #32 on: 21 May 2014, 06:28:28 pm »
Where is the collar/bush?
Re: weave /wobble
« Reply #33 on: 21 May 2014, 08:36:38 pm »
Not included with this kit.....swing arm is a bit different to wheel spindle.wheel has center spacer and two sleeves/collars that run on the roller wheel bearing, on the swinging arm these three pieces are one.....old one was very good so I cleaned it up and re-lubed....
Re: weave /wobble
« Reply #34 on: 21 May 2014, 08:47:22 pm »
Fitted the new bearings tonight.......my drift was'nt going to work, not enough room to get it in there, so I prised the rollers out and removed the plastic roller carrier from both sides I then used a length of 22mm copper tubing to knock the outer bearing casing out.....worked a treat  :D.......cleaned everything up and pressed the bearings in square with my hands just to get them started, I then used a sash cramp to push them all the way in, then using a scoket slightly smaller than the bearing for the last little bit
 Dropped the spindle in and no play what so ever   ;).....will put it back on the bike tomorrow.
Re: weave /wobble
« Reply #35 on: 21 May 2014, 09:05:24 pm »
You just cannot beat improvisation, it's the mother of invention. :)
Are you going to patent that bearing tool :lol
Are the frame rubbers covering the Spindle in good condition. Put some grease inside them to stop and water ingress and don't forget to grease the bearing covers.
Enjoy the test run tomorrow :)
Re: weave /wobble
« Reply #36 on: 21 May 2014, 09:36:16 pm »
Pat applied for   :lol....this time next year I'll be a millionaire   :rollin......yep..both caps in vgc.....will be well greased, thanks for the tip....bearing covers already fitted and packed with grease..... :)
Re: weave /wobble
« Reply #37 on: 21 May 2014, 09:49:18 pm »
Nice one Red,  noticed a bit of play on my swing arm the other week,  tightened up the nut and it's better but still a bit of play. Will refer to this post when I attempt mine.  Cheers.
Re: weave /wobble
« Reply #38 on: 22 May 2014, 06:50:02 am »
hi dazza....its an easy job,bearings under £30....roller bearings , so nipping your nuts is not really going to work  :\ ...all being well i`ll have it all back together tonight and have a test ride .....
Re: weave /wobble
« Reply #39 on: 23 May 2014, 10:41:40 pm »
All back together tonight and out for a test ride....very smooth and stable  :D.........well done CRH..for guessing correctly you have won a prize  ;)
Re: weave /wobble
« Reply #40 on: 23 May 2014, 10:43:49 pm »
Re: weave /wobble
« Reply #41 on: 23 May 2014, 11:10:14 pm »
And the prize is the old set of swinging arm bearings :lol
Another happy foccer :lol
CRH
Re: weave /wobble
« Reply #42 on: 24 May 2014, 07:25:11 am »
All back together tonight and out for a test ride....very smooth and stable  :D .........well done CRH..for guessing correctly you have won a prize  ;)
....kin hell paul"...thats some lawn ya got there matey? :eek ....yes thanks for the applause" ;) ....think i deserve at least a fkn towbar though?...cus ya never sent me my last prize" after i diagnosed ya stuuter!!!!! :rolleyes .....
Re: weave /wobble
« Reply #43 on: 24 May 2014, 08:36:06 am »
yesssssss you lucky foccer....the towbars yours   :lol :lol :lol .........not sure you diagnosed the stutter or not  :rolleyes ...i`ll go back and re-read the "stuttering thread" and see.........see you in a couple of weeks  :rollin :rollin
took that picture last night 9.30 at local park whilst on my test ride......poor quality as taken with phone and not much light.......thou looks good though  ;) [size=78%] [/size]
