Date: 23-03-26  Time: 00:52 am
Author Topic: Preload  (Read 4591 times)
hightower
Preload
« on: 08 May 2014, 04:25:41 pm »
I think I'm on position seven or 3 depending which way the numbers start. Can somebody tell me which way the numbers on the rear preload start. Is 1 at the lowest point on the adjuster (the adjuster I'm referring to looks like steps) or at the top
karlo
Re: Preload
« Reply #1 on: 08 May 2014, 04:57:26 pm »
Tells you in here 1 being the softest setting.
http://foc-u.co.uk/index.php?action=downloads;sa=downfile&id=8
hightower
Re: Preload
« Reply #2 on: 11 May 2014, 10:12:12 pm »
I know 1 is soft and 9 is hard. It just doesn't say which is position 1 and which is 9
midden
Re: Preload
« Reply #3 on: 11 May 2014, 10:25:00 pm »
Does it really matter?  call it 1 or 9 it's either one will be the softest or the hardest depending on your choice.
The manual works 1 as softest though ;)
hightower
Re: Preload
« Reply #4 on: 12 May 2014, 10:14:55 am »
I didn't think it was that hard a question. Perhaps I could have worded it better.
I have attached a lovely hand drawn picture of what my suspension adjuster looks like. The red dot, is that in position 3 or position 7? That's what I can't find in the manual - whether position 1 (softest) is the lowest (left hand) setting or the highest (right hand) setting.
Does this make sense? Does the numbering system start at the lowest point and work up, or start at the highest point and work down?
hightower
Re: Preload
« Reply #5 on: 12 May 2014, 10:17:40 am »
To make the question even clearer, does the numbering system in the manual work like option A or option B of the attached images?
midden
Re: Preload
« Reply #6 on: 12 May 2014, 10:25:41 am »
Number 1 will be the lowest step and spring basically with no loading ie uncompressed. As the steps are climbed the spring is further compressed (preloading)
Option A
hightower
Re: Preload
« Reply #7 on: 12 May 2014, 10:33:35 am »
I realise it is probably a stupid question which is why it might have been read wrong. Just wanted to clarify as the manual says 1 is soft but without actually seeing any numbers on the adjuster.....
Anyway, thanks,
Re: Preload
« Reply #8 on: 12 May 2014, 06:49:22 pm »
Just looked at your pictures ......adjusting the preload will make no difference what so ever.......with that spring   :rollin  :rollin  :rollin
johna6968
Re: Preload
« Reply #9 on: 12 May 2014, 09:15:33 pm »
Hey those pics are great.. Respect  :thumbup
hightower
Re: Preload
« Reply #10 on: 13 May 2014, 08:17:45 am »
Some say I'm a Photoshop wizard. Me? I just think I'm better than average :)
@Red - yeah, the springs are next on the list ;)
johna6968
Re: Preload
« Reply #11 on: 13 May 2014, 01:01:15 pm »
Your artistic skills my friend know no bounds... Increasin preload = increasin numbers... Yup Im also sat on no. 7 btw  :)
hightower
Re: Preload
« Reply #12 on: 13 May 2014, 02:08:40 pm »
I'm on number 9 now. Not feeling much difference though
johna6968
Re: Preload
« Reply #13 on: 13 May 2014, 02:21:10 pm »
I always like to leave a little psychological leeway for carryin piliion  :lol
adeejaysdelight
Re: Preload
« Reply #14 on: 14 May 2014, 03:57:44 pm »
The standard rear shock is shite anyway. Preload only affects the useable range of movement on the spring, not the tension of the spring itself.
I have sent the last couple of evenings reading this -
http://www.amazon.co.uk/Suspension-Tuning-Handling-Stability-Control/dp/1893618455/ref=sr_1_2?ie=UTF8&qid=1400079262&sr=8-2&keywords=motorcycle+suspension
Therefor I am now an expert and guru and am here to advise you all on everything to do with suspension from this point fourth.
Re: Preload
« Reply #15 on: 14 May 2014, 04:17:27 pm »
You see I have never had a problem with it,  could it be im only 10 stone with a full belly of pies
johna6968
Re: Preload
« Reply #16 on: 14 May 2014, 05:17:28 pm »
Wow.. It mus go like a thou  :lol
adeejaysdelight
Re: Preload
« Reply #17 on: 15 May 2014, 07:59:42 pm »
I float between 65-70 kilos, but I found the standard scock soft and saggy. Maybe its how I ride, maybe mine was past its best. But it was shite. There are plenty owners on here have upgraded to an R6 shock or better. I am one of them. It is a sound investment if you like to explore the full capability of the machine.
