Date: 25-04-26  Time: 00:36 am
Author Topic: nitron shock problem  (Read 2550 times)
carlos
« on: 23 April 2014, 09:06:40 pm »
hi foccers I have just managed to fit my nitron shock to my 99 fzs but have found the bottom shock bolt just a bit to short with the thicker shock fittings on the nitron the mountings are about 2 mm thicker either side.
this means the nut cant fully get on the bolt.
any on else had this issue?? it will go on fully if I leave the washer off is this a good idea??
carlos
Re: nitron shock problem
« Reply #1 on: 23 April 2014, 09:24:09 pm »
I thought about that but am concerned the bottom shock bolt takes a heavy load so should it be high tensile?
or stainless
midden
« Reply #2 on: 23 April 2014, 10:06:39 pm »
or stainless
So ask for a longer high tensile or stainless bolt ;)
No engineering firms nearby?
carlos
« Reply #3 on: 23 April 2014, 10:16:59 pm »
looks like I will be looking for decent engineering firm tomorrow
Punkstig
« Reply #4 on: 24 April 2014, 02:48:43 am »
Are you sure you didn't get the bolts mixed up by mistake?
My nitron fitted fine with the standard bolts!
carlos
« Reply #5 on: 25 April 2014, 07:26:02 am »
to late its on with thinner washer and Loctite for good luck
didn't get them mixed up punkstig seems to be ok
