Date: 10-05-26  Time: 20:21 pm
Author Topic: Urgent help needed  (Read 10491 times)
hightower
Urgent help needed
« on: 08 April 2014, 01:03:51 pm »
Please help. This is my cam on rebuild, the crank is tdc, the markings are a little clockwise of where they were before.
Is this OK?this little difference doesn't seem like a tooth's worth. If I rotate the cams 1 tooth anticlockwise the markings then line up after so no closer.
Can I accept these timings or will me engine go pop?
Here's before pic for more info
Skippernick
Re: Urgent help needed
« Reply #1 on: 08 April 2014, 01:23:17 pm »
Top pic is the inlet cam and the bottom pic is the exhaust cam, assuming you have taken the pics from the same side, not sure if it makes a difference comparing them.
« Reply #2 on: 08 April 2014, 01:50:53 pm »
Is the camchain tensioned?
hightower
« Reply #3 on: 08 April 2014, 02:20:07 pm »
I was a tooth out....  :(
Took it all off again to sort but now lost a dowel from the cam holders. Can't find it.... Feel like crying
His Dudeness
« Reply #4 on: 08 April 2014, 02:26:00 pm »
Hope it's not in the engine!
noggythenog
« Reply #5 on: 08 April 2014, 02:29:06 pm »
Hightower
Not being cheeky
But i can see where this could end up
Would you like me to put dibs on my engine
I'll do you a good price
Just sayin
Good luck 8)
hightower
« Reply #6 on: 08 April 2014, 02:31:45 pm »
Can't find it anywhere. I dropped it towards rear of bike so if in engine it's a good shot. Fed up now, thinking of leaving it for today as just getting agitated
richfzs
« Reply #7 on: 08 April 2014, 02:38:25 pm »
Walking away is a good idea at this point - I got frustrated a couple of weeks ago, and launched my 5mm thandle Allen key across the garage - no idea where it went, quite annoying not having it!!
hightower
« Reply #8 on: 08 April 2014, 02:43:04 pm »
Yeah I'm done. Quick question. Would one of the cam holders not having a dowel be the end of the world. The dowels just to help seat it right, so if it has 2 still and all it's screws will that be a problem.
Looked everywhere i can on bike - nowhere to be seen
hightower
« Reply #9 on: 08 April 2014, 03:02:50 pm »
And if not where can I order one from
headgonekneedown
« Reply #10 on: 08 April 2014, 03:43:11 pm »
Its there for a reason!
richfzs
« Reply #11 on: 08 April 2014, 03:49:26 pm »
Are you sure it stayed on the bike?
richfzs
« Reply #12 on: 08 April 2014, 03:51:19 pm »
Oops, posted early... It didn't go to the ground? Try putting a good torch right down at floor level, shining across the floor - it's the best way to find small components, it highlights the shadows created... And yeah, it'll be there for a reason...
hightower
« Reply #13 on: 08 April 2014, 05:00:49 pm »
Darn it, I think I need to order one then. I spent about 2 hours searching today in the garage. Any ideas where?
His Dudeness
« Reply #14 on: 08 April 2014, 05:20:30 pm »
Are you 100% certain it's missing? They can get stuck in the cam cap when you take the cap out or they can get stuck in the head.
hightower
« Reply #15 on: 08 April 2014, 05:30:38 pm »
Yeah, I felt and heard it drop (I dropped another and also a bolt at the same time). I found them, but this could be anywhere as I didn't see it fall. I've counted my dowels about 20 times today, it's definitely missing. Gonna go give it another search in a bit.... Not very hopeful.
hightower
« Reply #16 on: 08 April 2014, 05:45:52 pm »
Just ordered a couple from aj sutton, just gotta wait it out now  :(
Better safe than sorry. Will have one last look in garage tonight too.
Deefer666
« Reply #17 on: 08 April 2014, 05:48:58 pm »
If the cams are in then it could not have gone far, just check under the cams, then rotate the engine by hand from the crank. If it went down a plug hole it'll lock the engine. I did an XJR for a customer where a dowel dropped down the bores as I was fitting the cams.... Soul Destroying, I feel ya pain
hightower
« Reply #18 on: 08 April 2014, 05:50:17 pm »
2 weeks to get the part as not held in stock
Deefer666
« Reply #19 on: 08 April 2014, 05:52:09 pm »
PM my your address and I'll stick one in the post
hightower
« Reply #20 on: 08 April 2014, 05:52:33 pm »
You got one spare?
Deefer666
« Reply #21 on: 08 April 2014, 05:55:13 pm »
I have lots of engines kicking around that have all been robbed of their selector forks and mechanisms to fix customers fazers. I think I'll be able to spare one!  :rollin
ogri48
« Reply #22 on: 08 April 2014, 05:59:25 pm »
nicely done deefer :)
savvy
« Reply #23 on: 08 April 2014, 06:52:17 pm »
What a guy :)
« Reply #24 on: 08 April 2014, 07:23:02 pm »
Were the plugs in or out when you lost the dowel ?  If in it may have gone down the cam chain tunnel, shine a torch down there might see it.......taking the sump off is easy, might have fallen to the bottom.......if plugs out , if it were me I would take the head off again to make sure, you hav'nt started it so gasket should be ok........done a simular thing with  a valve shim....fell in slow-mo down the plug hole, only way to get it out was to take the head off.......good luck.hope you find the bugger on the garage floor somewhere    :)
