Date: 22-03-26  Time: 21:46 pm
Author Topic: Front end swap to USD forks (done and now with pics and write up)  (Read 26513 times)
Geordi Sussex
Just made a deal for a YZF front end
Hopefully with swapping out the steering stem for the fazer one it will be a hassle free fit
But before it gets on I think I'll swap out fork seals
Any idea if the fzs calliper will fit onto yzf for legs?
Chris
Re: Front end swap to USD forks
« Reply #1 on: 02 February 2014, 09:48:33 pm »
not sure about the calipers, I'd assume probably not.
Have you got a solution for the speedo?
Chris
Punkstig
« Reply #2 on: 02 February 2014, 09:56:04 pm »
Depends on the wheel, luckily for mine it was simples, just had to file down the plastic pins from the sensor to fit flush with the Thundercat wheel!
As for the calipers not sure if you've got an R1 or R6  front end or what year, early ones are the same I believe.
I hope it's the entire front end (wheel, fender etc)
If not the fazer wheel and calipers will need spacing out!
Don't be surprised if the steering lock stops don't hit, and chances are the controls will hit the fairing before they did anyway- this isn't an issue, just reduces the turning circle, not only that but if using the clip on bars there may be the opposite issue of clearance against the tank.
You can keep the fazer handlebars but will obviously need to drill out the top yoke before fitting!
If you got it for the right price it's a good upgrade, have a day ready to go through it all
Geordi Sussex
« Reply #3 on: 02 February 2014, 10:01:37 pm »
Speedo solution is to replace the dials for a digital one
This will also be a smaller unit to fit behind the headlamp mask
Prob go for this one
http://bit.ly/1hZLfpb
If the callipers won't fit I think I'll refurb the yzf ones before the refit starts
Chris
« Reply #4 on: 02 February 2014, 10:04:37 pm »
Sounds good, looking forward to some pics!
Chris
Geordi Sussex
« Reply #5 on: 02 February 2014, 10:13:30 pm »
I have taken my inspiration from this bike
Looks like the forks stick out of the top yoke due to the difference of lengths on the stem/neck
Punkstig
« Reply #6 on: 02 February 2014, 10:28:44 pm »
Yeah they will stick out, this in turn can affect the angle of the standard bars!
Measure both forks and this will give you the length to have,the new ones coming out the top yoke to keep standard height
Andy FZS
« Reply #7 on: 02 February 2014, 10:38:15 pm »
If you need any measurements on the yzf let me know as my oldest son has one.
Andy
spencer_foxwell
« Reply #8 on: 05 February 2014, 09:33:03 am »
Hmmm.... How easy would something like that be to fit? Both my speedo and tacho are up the swanny so something like this might be the answer for me too. Only problem is I have clip ons so mounting it might be tricky.
That pic with the USD forks looks the business :D
Geordi Sussex
« Reply #9 on: 05 February 2014, 04:42:03 pm »
My mate has that speedo on his chop
He got it working ok and the instructions arnt too bad
Or wait till I get the digital one and by mine off me
spencer_foxwell
« Reply #10 on: 05 February 2014, 08:45:38 pm »
My bike is naked so your clocks would be a bit wrong on here :(
Geordi Sussex
« Reply #11 on: 05 February 2014, 10:53:03 pm »
Pix of the front end I'm picking up tomorrow
I have ordered a fork seal kit as I want to refer  them before I put them on
Also going to get a brake caliper referb kit and make sure it's all working and safe before assembly
Fuzzy
« Reply #12 on: 06 February 2014, 04:35:29 pm »
I think the calipers fit the forks as I recall the blue spots are a popular upgrade with YZF owners
Geordi Sussex
« Reply #13 on: 06 February 2014, 06:36:46 pm »
Hi fuzzy
I'm not sure about that but it's somthing I can look at
I would have thought that 6 pot calipers would be better than the fazer 4 pots?
Please correct me if I'm wrong as I want to only work on it the once lol
Fuzzy
« Reply #14 on: 06 February 2014, 06:38:45 pm »
4 pot blue spots will be superior matey, more pots do not necessarily equal better braking.
Punkstig
« Reply #15 on: 06 February 2014, 08:36:12 pm »
Correct, on my SRAD750 6 pots were standard and they were shockingly shite, swapped for the 600 4 pots as did every other owner!
Geordi Sussex
« Reply #16 on: 07 February 2014, 12:03:37 am »
Cool thanks for the advice
Well it could save me £60 on a referb kit if that's the case
Geordi Sussex
« Reply #17 on: 13 February 2014, 06:22:25 pm »
Ok first update
The stem from the fzs600 is 30mm where it goes into the yoke
The yzf750 hole for a stem is ?????
30mm
I think we have a winner
I also have found a machine shop with a press that can take out the stem and refit it
They also will mill out the caliper carrier so I can for the fzs600 blue dots
Fuzzy
« Reply #18 on: 14 February 2014, 12:03:13 pm »
Looking good!
Chris
« Reply #19 on: 14 February 2014, 02:00:14 pm »
Awesome! Will the brake line clear the bracket too?
Chris
Geordi Sussex
« Reply #20 on: 14 February 2014, 04:36:28 pm »
I have to say there not my pix that's what I'm going to be doing.
Should be able to make a start next week on it
Fingers crossed this front end swap will be Strait forward
Geordi Sussex
« Reply #21 on: 17 February 2014, 09:26:38 pm »
Just a little update
I've managed to score a used pair of blue dot calipers
So next week I'll be getting the stems swapped and the calipers carriers milled
ChristoT
« Reply #22 on: 17 February 2014, 10:47:52 pm »
Fuzzy
« Reply #23 on: 17 February 2014, 10:50:33 pm »
I think he's got yzf750 forks already no?
ChristoT
« Reply #24 on: 17 February 2014, 10:55:41 pm »
Geordi does, I want to know if those will fit mine!  :rollin
