Date: 07-05-26  Time: 01:02 am
Author Topic: Crash bars  (Read 11795 times)
Punkstig
Crash bars
« on: 26 January 2014, 05:37:33 pm »
Right, who's got what and what do you see as the negative points of them?
I've got crash bungs atm but know from several previous experiences these are only good for dropping the bike at a standstill (which I've also done several times!)
I've narrowed my choice down to either Heed or Renntec, the full engine crash bars, not the smaller ones!
mickvp
Re: Crash bars
« Reply #1 on: 26 January 2014, 05:43:35 pm »
I've got the full renntec ones on. Apart from being heavy, bulky and (some would say) ugly, theres no real negatives to them. I've yet to test mine out yet though thankfully.
Fuzzy
Re: Crash bars
« Reply #2 on: 26 January 2014, 05:46:12 pm »
I have the smaller ones with the three mounting points - these:
http://www.wemoto.com/bikes/Yamaha/FZS_600_Fazer/98-99/picture/Engine_Bars_-_Black/
I've dropped the bike once at a stand still since I've had these fitted (2 or 3 years, quite an acheivement for shortarsed me) and they did a considerably better job than the crash bungs fitted previously which allowed the edges of the front fairing to hit the deck and get foc'ed up. Like you, I think crash bungs on the 600 are not very effective, I think their position low down makes them less than ideal.
Renntec & Heed (latter look neater to me) look beefier but the above has done everything I'd expect from crash bars so the fact they're smaller, lighter & cheaper is a positive point in my book.
Re: Crash bars
« Reply #3 on: 26 January 2014, 06:03:19 pm »
We id all this here http://foc-u.co.uk/index.php/topic,1655.msg95874.html#msg95874
Im not sure about the webmoto being 3 pionts as the top one is on a long bar attached to a point much lower
Sorry just read that you are on about the larger ones
Fuzzy
Re: Crash bars
« Reply #4 on: 26 January 2014, 06:11:39 pm »
Yes, you're right they are in reality only attached to the frame at 2 points (I was just trying to differentiate from the ones in the 1st photo in your link)
What I did notice was that - whether intentionally designed to do so or not - because they are bolted to those plates, the bars can move a small amount, so there is a bit of "give" and the force is not directly transferred to the frame or engine bolts, not straight away at least. Another bonus is that it is very easy to remove the bars as you can simply remove them from the plates so you can leave the engine bolts in situ.
Re: Crash bars
« Reply #5 on: 26 January 2014, 06:25:33 pm »
In that respect they are good
Punkstig
Re: Crash bars
« Reply #6 on: 26 January 2014, 06:39:20 pm »
As well as protection my plan is to rivet sheet ally creating a belly pan, this is the main reason I'm looking at the bigger bars.
I'll have to eye things up cause in my mind I still can't decide whether to rivet over the top of the bars hiding them or under the bars to look a bit different!
Fuzzy
Re: Crash bars
« Reply #7 on: 26 January 2014, 06:43:09 pm »
Oh I see, is the ally for cosmetic purposes only or will it do something more - keep the bike cleaner?
stevierst
Re: Crash bars
« Reply #8 on: 26 January 2014, 06:46:58 pm »
The bigger and beefier the bars, the better! Had a set on my tiger 1050. When it went down the engine and frame were untouched, the crash bars were mangled!
Worth every penny.
mickvp
Re: Crash bars
« Reply #9 on: 26 January 2014, 07:18:43 pm »
heres mine for reference (I think they are renntec at least? came on the bike anyway!)
Punkstig
Re: Crash bars
« Reply #10 on: 26 January 2014, 08:31:26 pm »
Mick - I know the renntec's have a hole for where the bung in the frame is, are they bolted through that part of the frame too? (below the seat, not the front of the bike!)
Punkstig
Re: Crash bars
« Reply #11 on: 26 January 2014, 08:32:47 pm »
Looking closer at the pic I'm assuming they're bolted in with the footpegs, is that right?
mickvp
Re: Crash bars
« Reply #12 on: 26 January 2014, 08:33:30 pm »
aye, one of the bolts is into the footpeg/hanger :)
Punkstig
Re: Crash bars
« Reply #13 on: 26 January 2014, 08:53:15 pm »
Just one?
Punkstig
Re: Crash bars
« Reply #14 on: 26 January 2014, 08:54:04 pm »
The thing is the renntec's are more expensive than the Heed but if they bolt into the frame there that makes them a lot stronger!
Punkstig
Re: Crash bars
« Reply #15 on: 26 January 2014, 08:55:15 pm »
Both, bearing in mind it'll probably be covered with tiger print!
mickvp
Re: Crash bars
« Reply #16 on: 26 January 2014, 09:00:34 pm »
Just one?
just gone out and looked. there are two at the rear (both the top and bottom mounts for the footpeg hanger).
also one bolt at the front top into the frame, and one at the bottom front as well :)
Re: Crash bars
« Reply #17 on: 27 January 2014, 12:15:11 am »
I have the genuine Yamaha ones, 5DM-W0741-00
It has been down the road 3 times and the saved a lot of damage to the engine casings. On my 3rd set. Had black, then chrome and now back to black again
http://kleinanzeigen.ebay.de/anzeigen/s-anzeige/original-fzs600-sturzbuegel-5dm-w0741-00-neu-ovp/173493263-222-4719
Punkstig
Re: Crash bars
« Reply #18 on: 27 January 2014, 08:19:35 am »
Yeah, I don't like them unfazed,  no supporting arm so mot as beefy as the Heed or Renntec!
Re: Crash bars
« Reply #19 on: 27 January 2014, 04:57:45 pm »
I thought the same before my first off. I bought them originally for looks and fall over protection.
Was plesently surprised when they took the brunt in a the slide without anything other than road rash.
Re: Crash bars
« Reply #20 on: 27 January 2014, 07:46:55 pm »
you only need the olwers that I have got because they stick out far enough to protect the engine
Re: Crash bars
« Reply #21 on: 27 January 2014, 08:36:50 pm »
I like to have the rad protected also. You can ride with bent leaking forks,  :lol (speaking from experience) but not with a bent leaking rad
Arfa
Re: Crash bars
« Reply #22 on: 11 February 2014, 12:40:16 pm »
So, been looking again at getting some bars for the bike.
With the Heed or Renntec ones with their cross bar, do any of you find gets in the way of your legs/feet at all?
So I've been looking at the Yammy ones, seems there's a few variants:-
The lower rounded mini one: 5RT-W0741-00 (as pictured in this Fazer brochure)
And the squarer taller ones: 5DM-W0741-00 / 5DM-W0741-10  (black/chrome)
These last ones, seem to come in two versions, one where two halves meet in centre of bike and one where they don't.  Can anyone shed some light on these two version? Foxeye/Boxeye versions? older/newer iterations?Granted, neither will provide as much protection as the more encompassing Heed/Renntec bars, but I think I prefer the more discreet look of them. And from much experience, the rear of the engine doesn't hit the ground anyway, as my pegs and Givi rack/box take the impact first...
Fuzzy
Re: Crash bars
« Reply #23 on: 11 February 2014, 01:01:32 pm »
Arfa
Re: Crash bars
« Reply #24 on: 11 February 2014, 01:17:11 pm »
Yep. Also seen some other genuine ones about second hand too. ;-)
