Date: 07-05-26  Time: 08:56 am
Author Topic: headlamp bulbs  (Read 3442 times)
codgie
headlamp bulbs
« on: 06 November 2013, 08:14:37 pm »
can anyone suggest a brighter bulb for my head lights
dip beam is useless
main beam is on the floor about ten ft away :'(
bwizz
Re: headlamp bulbs
« Reply #1 on: 06 November 2013, 08:26:05 pm »
If you have done the "making both lights work on dip mod"  then I don't think you will gain much improvement with the box eye headlamps,  you could end up melting the lens assembly by going more amps route. I tried better bulbs in my car but there was not much improvement, I suppose HID lamps are an option ,but iv'e no experience of them , expensive to !
Re: headlamp bulbs
« Reply #2 on: 06 November 2013, 08:27:55 pm »
Osram Nightbreakers or Philips Xtreme
You should really get the mod done as well though, one light only is simply not good enough in the dark.
codgie
Re: headlamp bulbs
« Reply #3 on: 06 November 2013, 08:29:10 pm »
what bulb numbers do i look for ??
Re: headlamp bulbs
« Reply #4 on: 06 November 2013, 08:33:23 pm »
H1 & H4
codgie
Re: headlamp bulbs
« Reply #5 on: 06 November 2013, 08:47:35 pm »
thanks
Gav
Re: headlamp bulbs
« Reply #6 on: 07 November 2013, 10:59:52 am »
I just fited another headlamp box into my fazer bcus the one init had a crack in the perspex.
Anyway both my head lights come on with low beam and inside the headlamp box I took off, I noticed the silver coating had melted and the bulb holder has started to crumble and disintegrate from constant heat.   Is this normal from a modded fazer with having both bulbs come on for low beam?
Re: headlamp bulbs
« Reply #7 on: 07 November 2013, 12:22:28 pm »
They are fragile anyway (bloody useless) but i'd imagine it's been caused by bulbs that were too hot.
That's why i always suggest using plastic friendly bulbs, although that's more to do with stopping the lenses from discolouring.
I wrapped strips of amalagamating tape around my bulb holder to keep the heat away and to stop the very annoying vibration.
Not sure about what you can do with it, but with a bigger hole maybe you could upgrade it to an H4 instead?
I just took that silver shroud thing off as it was falling off anyway, i think that's quite a common issue.
apage16
Re: headlamp bulbs
« Reply #8 on: 07 November 2013, 12:43:06 pm »
I took my silver shroud off too. It was flapping around as most of the reflector had disintegrated. MOT was no trouble like this. And I'm pretty I got more light out the front too!
Interesting thing is that when I came to completely upgrade my headlights with projector units, I had to cut away at the reflector (which, incidentally, was flaking waaay worse than yours Gav! You've got a good one!). The plastic immediately around where the headlight fitted just crumbled away like I was dremmelling a sand castle! But it then became INCREDIBLY hard! Blunting a few of my cutting tools and wearing out abrasive attachments in seconds.
Good work Yamaha, complete materials specification FAIL!
dcurzon
Re: headlamp bulbs
« Reply #9 on: 07 November 2013, 12:44:53 pm »
I got a pair of H1 and H4 osram nightbreakers for around £25 delivered from Amazon - one set fitted, one set under the seat.  Not too bad
BUT!
Although the light is MUCH better than before, it's still not great!
So i'm awaiting some HID's from China... 1x H1 and 1xH4, £23 delivered.  Will let you's know how they go
Re: headlamp bulbs
« Reply #10 on: 07 November 2013, 01:06:29 pm »
The lights on the Fazer are worse than any bike i've ever owned, which is a real shame.  :\
apage16
Re: headlamp bulbs
« Reply #11 on: 07 November 2013, 01:10:05 pm »
My first geared bike was a KH-100. That had a glow-worm in a jam jar strapped to the front!! :lol
Re: headlamp bulbs
« Reply #12 on: 07 November 2013, 01:57:50 pm »
Sometimes i feel like i should be wearing a miners helmet  :lol
Gav
Re: headlamp bulbs
« Reply #13 on: 07 November 2013, 05:37:35 pm »
Might put a couple of tea lights in the headlamp box before I ride mine in the dark again.  Might be able to see something then.
