FZS600 / loose hose from carburation
Yesterday I thoroughly cleaned the bike after a very wet weekend with my buddies. When I finished removing dirt from behind the cylinders, I saw this loose hose on the left side of the engine block. In the photo, it is between the clutch cable and the long hose going down (I guess it is the fuel tank overflow). Can someone tell me where I need to connect this shorter loose hose? It comes from somewhere between carburetors 3 and 4.
I do know that there is an opening on the back (not visible) of the front sprocket cover where the loose hose could fit in. A carburetor overflow perhaps?
Maybe someone could take a close-up photo showing how this hose should be installed. Thanks in advance.
UPDATE:
For the moment I led the hose opening into the gap on the backside of the sprocket cover. The second picture shows on the right the clutch cable. The position of the rubber hose in the gap is just under the hex bolt.
.jpg   loose hose careburation FZS600.jpg (Size: 87.91 KB / Downloads: 36)
Check where the other end of the hose is connected first, of the top of my head that looks like an overflow hose for when you drain the carbs.
(23-05-26, 09:39 AM)b1k3rdude Wrote: Check where the other end of the hose is connected first, of the top of my head that looks like an overflow hose for when you drain the carbs.
"It comes from somewhere between carburetors 3 and 4."... Counting from left to the right. And yes, I expect it is some kind of overflow and on the loose end of the hose no hose clamp.
But if someone will post a clear close-up picture about that area above the clutch/sprocket cover as I did, that would probably clarify a lot.
.jpg   20260526_010513.jpg (Size: 53.16 KB / Downloads: 17)
.jpg   20260526_010558.jpg (Size: 59.7 KB / Downloads: 17)
.jpg   20260526_010905.jpg (Size: 59.7 KB / Downloads: 17)
These any good, pipe goes down oil fill side.
.jpg   Screenshot_20260526_023116_eBay.jpg (Size: 79.13 KB / Downloads: 17)
If those 2 hoses are currently routed so they are poking out below & next to the center stand, then someone will correct me if wrong, but I believe these are just breather hoses.
(26-05-26, 08:17 AM)b1k3rdude Wrote: If those 2 hoses are currently routed so they are poking out below & next to the center stand, then someone will correct me if wrong, but I believe these are just breather hoses.
Yup would suspect as much or over flows, either way if its running ok stick it down the side with others see what happensĀ  Cool
Faze2 replied: "These any good, pipe goes down oil fill side."
That is a very likeable suggestion. I probably shoved it to the other side (from the right tot the left) with a cleaning brush and because of the loose end of the hose (it wasn't fixed with a clamp).
b1k3rdude replied: "If those 2 hoses are currently routed so they are poking out below & next to the center stand, then someone will correct me if wrong, but I believe these are just breather hoses."
Quite logic, because of the absence of a clamp. I think it's now clear to me.
Thank you guys for the input.
Thumbup
(26-05-26, 10:51 PM)Ulympos Wrote: Faze2 replied: "These any good, pipe goes down oil fill side."
