01-04-26, 06:12 PM
Hello, I have a FZS600 Fazer Foxeye from 2002 (5RT1), but the ignition switch needs to be replaced because its worn and the key struggles to turn.
I want to be replace it as a set to be able to use the same key for both the gas cap as the ignition switch once replaced.
However here in the Netherlands I can't find any ignition switch + gas cap set for the 2002 model, but there is one available for the 2001 model.
Is there any difference in these two parts? The part# are different for both models, but they look very similar if not the same if you ask me.
Part# for FZS600 2001:
Ignition Switch: 4NA825010200
Fuel Gas Cap: 4HM246020100
Part# for FZS600 2002:
Ignition Switch: 5LV825011000
Fuel Gas Cap: 39P246020000
Thanks for any help
Thanks for any help
