FZ6 - bargain???
Gents,
FZ6 for sale, £3350 - 2014 plate - interesting!
Questioned it with the dealer, turns out, 2009, first registered in 2014.
12000 miles - 2 owners
Bargain or avoid??  Won't be many Fazers with a 2014 number plate lol
https://www.ebay.co.uk/itm/336194125319?...R9j73su5Zg
Looks like the paint is flaking off on the front forks, rear tyre is squared off, and the chain looks tight and in need of some lubrication. IIRC, 12k is the valve clearance check too. Probably more of a bargain at £2,800 from a dealer. Check the date on the tyres, might be the originals.
(10-10-25, 11:52 PM)agricola Wrote:  IIRC, 12k is the valve clearance check too.
Nope, it's 24k on the FZ6.
Ooops
(10-10-25, 04:15 PM)HarryHornby Wrote: Bargain or avoid??  Won't be many Fazers with a 2014 number plate lol
Avoid. Looking on Autotrader there are 2 bikes with far less mileage going for much less money -
- https://www.autotrader.co.uk/bike-search...=relevance
But there are issues with both of them aswell, the blue one has been dropped on the left hand side and the black one has marks all over and the rear tyre is underinflated.
The FZ6 is getting long in the tooth now, so personally if you have £3500 to spend, look at the MT07, FZ8 or FZ1 -
These ae a few S2 models on Autotrader
https://www.autotrader.co.uk/bike-detail...6flrfc%3D1
2 are private and they may haggle
Look up Autotrader under FZ6 Fazer and use S2 as the Keyword
(12-10-25, 11:09 PM)unfazed Wrote: These are a few S2 models on Autotrader
2008 Dark Blue:
- price too high for age/mileage, needs to be below £3k. Owner is prolly trying to cover the cost of the luggage/topbox - ask if they will remove. Remember 3rd party items do NOT increase the value of the bike.
- check for wear damage from the soft luggage.
- corrosion on the headers
- corrosion on the rad side plates
- dirt or paint damage on the front wheel rim.
- front brake discs looks worn, would have to examine in person.
- to many photos of the same angle with poor exposure. Not enough close up photo's,
- owner doesn’t know how to go around corners, tyres have large chicken strips. This would then suggest the owners commutes only and the tryes might be starting to square off.
- Wasn’t able to check the age/wear of the tyres
2008 Silver:
- custom rad guard has a big dent to the r/h side, ask owner to remove it to show there is no damage to the radiator.
- I can see just a hunt of damage to the crash bung can on the same side, ask why this is.
- some scuff marks to the bottom of the timing cover, check if that’s just wear and tear or actual drop damage.
- scuffs on the same side of the swingarm.
- rear break disc is worn and may need replacing, check width with cheap micrometer to verify it will still have an MOT.
- paint pealing off the rear wheel, this will need touching up to stop it getting worse. Wheel will need a complete repaint eventually.
- lower l/h side of the fairing mount point has a stress crack, this will need a repair to stop it spreading.
- drive chain need a proper clean and lube (owner has been poorly lubed chain in image), check for tight spots, it any found, bike will need a chain and sprocket kit.
- crash bung has crash damage but it pointing the wrong way. I suspected it the bung from the other side that has been swapped around.
- generator cover looks like it has some gravel rash.
- owner appears to done half a job cleaning the left side of the bike compared to the right side.
- gear lever rubber worn need replacing. Likely rear break pedal the same.
- the rear tyre has a date of December 2020, both tyres need to be replaced.
2008 Galaxy blue:
- cant see the engine due to the aftermarket full fairing.
- top of the front fairing non standard - @Grahamm can you confirm?
- r/h rear exhaust hanger loose, misaligned, worn.
- headers have corrosion, fairing need removing and close-up shots of the engine/headers taken.
- front disc/s look to be worn.
- on a side note, out of the 3 bikes this one has no crash protection. (So at a guess a carefully drilled hole in the fairing would be required and standard mushrooms fitted with spacers to protect the aftermarket fairing.)
- out of the 3 bikes, this has the most appropriate price.
Bikes are never worth what the owners think as the price is based on the the value it is to them not the real value.
Always buy with the head do not buy not the heart, it could cost you a fortune.
One of the biggest issues with any FZ6 is the lower rear shock mount seizing and extremely difficult to remove.
The FZ6 suffers corrosion of connectors like many bikes, especially ones over 10 years old.
There has been some Rectifier/Regulator failures, but these I have come across are due to corrosion of connectors.
Best of luck on the hunt Harry
(Yesterday, 10:02 AM)b1k3rdude Wrote: 2008 Galaxy blue:
That doesn't look stock, but neither are the side fairings and belly pan, so maybe the owner bought them as a set (could have been after a drop, but you'd have to ask them).
(Yesterday, 11:27 AM)unfazed Wrote: Bikes are never worth what the owners think as the price is based on the the value it is to them not the real value.
If only there was a post on how to get it out... Wink
https://foc-u.co.uk/mybb/showthread.php?tid=81683
The orange S2 looks the pick of the bunch Harry, and in the fastest colour too, with some service history. Well overpriced though. Try making an offer that you would be happy to pay,m minus a bit, see what the reaction is. After all, the bike is sixteen/seventeen years old now
Cheers guys, so great advice!
Spoke to the chap about the blue one, lovely and local too, but something wasn't adding up around the owners and didn't get a good general feel. it's changed hands very quickly for the last 2 owners (neither was a dealer). I was about to pull the trigger on the silver one but it's been sold, but holy moly, you guys don't arf see flaws I don't!!
How about this one?
How about this one? Miles away, but I could train it there and make a day of it, LOL
annoyingly (in a way) it looks like I've sold my bike on Sunday. Means I need to ramp up finding a bike for me sharpish because I occasionally need it for work if either car is in the garage or there is a problem.
I love the look of the FZ8, but I'm worried it will be heavier. I've only ever ridden a 125 CBF and then 2 X red Fazers. I'm worried I won't like the extra weight/feel.
I keep looking at Street Triples, but I don't want to not have a Fazer! You guys have been amazing for years, have very fond memories of rideouts, I just not have a Fazer, just yet...... can I? Find me a sweet Street Triple that I can train it to to collect from Kent ;-)
