R6 shock swap
Following my introduction to the forum I was advised that an R6 shock maybe a better option than having the original shock refurbished. So, after doing some reading I found a 2017 R6 shock that had been serviced ready to go on a track bike but was never used. I opted for sleeving the holes M12-M10 rather than drilling out the top bolt hole on the R6 shock. I'm only 13 stone and never have a pillion so I'm sure the M10 bolt will be up to the job. 130mm dog bones and some washers. The hardest bit of the job was getting the washers on the top bolt. Took a fair few attempts but got there in the end.
I'm probably not a good enough rider to notice a huge difference but it definitely felt better damped and bit firmer sprung (the old one had a Maxton spring, to go with the Maxton fork internals). I think I need to add a bit of rebound on front and back but ir rides pretty good as is. I tried to find some factory settings for the shock and landed on 5mm thread showing as a starter for sag, 10 clicks out low speed comp, 3 turns out high speed comp and 9 clicks out for rebound damping. I'd welcome any comments or opinions.
The only other thing to do is tyres. Current ones are 9 years old. What's the accepted wisdom for best tyres on the Gen 1?
Cheers.
(02-09-25, 08:21 AM)JC71 Wrote: What's the accepted wisdom for best tyres on the Gen 1?
Oh this could get spicy  Lurk
Any modern sports touring tyre will be a heck of a lot better than what you have on there now. On the Fazer I have only tried Bridgestone's or Avon's and have stuck with Avon's as I much prefer their profile which gives more stability at all lean angles where the Bridgestone's seemed less keen to keep a line if you were leant over, plus the Avon's have it on longevity too. Are they the best tyre, or the best tyre for your needs, possibly not, but I'm in no hurry to try anything else.
Let us know what you choose and how you get on with them.
Thanks Pie Eater.
Don't think I've ever used Avons - would that be the Spirit ST's?
(02-09-25, 10:58 AM)JC71 Wrote: Thanks Pie Eater.
I've just fitted a pair of Spirit ST's. They are a very good all rounder - good warm up times and consistent grip wet or dry.
Yes that's their latest sports touring tyre  Thumbup
Thanks guys. How would the Avons compare to the Pirelli Angel GTs?
Anyone used the Angel GTs?
Are you planning on pushing the tyres to the limits?
If not, frankly, any modern big name sport touring tyre is going to be ok. The only real difference will be the price.
Yes Grahamm, I think you're right. I like to have a 'silly five minutes' like the rest of us but most of the time I go with the traffic or just ahead of it.
The Avons look like good value for money.
