Yesterday, 12:33 AM
started to take out the water pump and then decided to just do gaskets and never removed pump but now that im putting it back together, im finding that the chain has way to much play imo. i loosened the sprocket to allow me to take chain off but never did and went to tighten chain sprocket (lower) and its now got like 3-4 inches of play if not more, i can alost pop it off of the sprocket. i never removed clutch assembly and went through the oil pan. i initially started this job because i tracked down a tick/ rattle to the area the pump is at, and i cant find any way to tension said chain. is the chain stretched out? am i missing something? 7
also side note the bike gets hot really quickly and the carbs make a really weird almost pulsing noise at idle? ive cleaned themj out very roughly (its my first time working on a bike but im mechanically inclined so took it on. ive been told that they shouldnt make much noise if any at all. any help would be much appreciated as i am a bike noob after all lol. side note when carbs were cleaned they were never synced after wards so idk if thats the pulsing noise?
