Attention Electrical Gurus
Whilst out on Wednesday, I was made aware that when indicating, my lights dimmed slightly, matching the cadence of the indicator. Thinking it might be an earthing problem, I connected an independent earth to both the rear lights and indicators, but the fault persisted, even after connecting to the -ve of the battery. It makes no difference if the engine is running or not. Thoughts please.
(02-05-25, 07:41 PM)robbo Wrote: Whilst out on Wednesday, I was made aware that when indicating, my lights dimmed slightly, matching the cadence of the indicator. Thinking it might be an earthing problem, I connected an independent earth to both the rear lights and indicators, but the fault persisted, even after connecting to the -ve of the battery. It makes no difference if the engine is running or not. Thoughts please.
I'd be thinking an earth prob too Robbo from symptoms you're getting.
Dunno if you're aware or not, but these old Yamaha's have a shabby inadequate earth from factory, main earth lead is Battery ground direct to a starter motor bolt.
I'd be removing both ends of the main earth strap, Ohms test it for resistance with a meter, if it's high bin it & replace it, you can have green death within the crimp on either end of the strap & not see any visible sign of it externally.
While starter bolt is out, run a tap thru bolt thread, blow thread out, avoid using grease within an earth connection, yes paint grease or copper slip over it externally, never grease internally, a bare metal connection always works best, ensure you've clean bare metal on starter body & under bolt head, clean up both sides of earth strap at both ends if strap tests good with a meter, I'd also check the single white connector on the Black ground wire that runs over battery top, clean that up too, seen load of these failing, corroded & loose etc, if it's got green death, cut it out & replace it, if it's loose squeeze it up with pliers.
It's a good move on these old bikes to run a fresh heavy gauge earth wire direct from Battery ground to chassis, do same at both headlamp 3 pin plugs.
If that doesn't fix the fault, you've potentially some issue with a bulb connection or a even an incorrect bulb fitted.
Seen loads of 24v bulbs fitted.
Some modern bulbs have elongated soldered connections & don't work well in older Jap bulb holders, they arc across & can cause poor earth like symptoms.
Have you fitted any bulbs or Led's recently?
LED's can cause all sorts of problems in older bikes & cars.
If all the above checks out good, I'd be going thru the loom, starting at rear, pull every connector apart, check they're tight & clean, meter probe each side of every connector, wash out any grease you find, no grease conducts electricity.
Main loom multi-plug behind left front flasher is a well known corrosion point.
Be methodical is my advice or you'll just be wasting time chasing your tail.
Have fun ?
Have fun ?
Thanks for your reply Gaz, that’s given me plenty to get on with. No bulb changes or alterations have been made since I swapped out the rear indicators about 9 years ago. My pal, who I ride with a lot, only noticed the problem on Wednesday, having had 5 days in France together the previous week, so believe this has only just occurred. I’ll keep you posted, thanks again??
Hi Robbo, you can also take a look on Christian’s site for some good info. It’s in German but translates ok in my safari browser on the phone.
http://cvieth.bplaced.net/motorrad_licht.html
(04-05-25, 08:18 AM)Trebus Wrote: Hi Robbo, you can also take a look on Christian’s site for some good info. It’s in German but translates ok in my safari browser on the phone.
Thank you, I’ll have a look later. Plenty of racing on tv today?
