19-11-24, 12:28 PM
(This post was last modified: 19-11-24, 12:51 PM by CountFazer.)
Hi All,
My bike isn't firing on all cylinders.
At first cyl 1 didnt fire from cold sometimes. I swapped the spark plug cap with cyl 4 to try isolate the problem. Left it for a couple of days. Then when I started the bike cyl 3 was not firing.
I've now checked ignition coil resistance, spark plug cap & lead resistance and they were all normal. When I plugged everything back together, cyl 2 & 3 were not firing. I then swapped the plug caps around some more but still cyl 2 & 3 not firing.
However, if I pull the plug caps off the spark plugs a bit so that they are loose, the cylinders fire!
Any ideas would be greatly appreciated.
Cheers,
CountFazer
Cheers,
CountFazer
