Main ABS Fuse in Gen2
Hello, the ABS on my 2012 FZ1-SA has been playing up. When I start the bike it seems fine, the light goes off, but after a bit of riding it will start engaging at the latest touch of the lever, or sometimes releasing the brakes before activating again - scary. After a couple of hard squeezes the ABS light comes on and it stops working completly, leaving me with normal brakes.
Restarting the bike reset the whole thing, it starts working again and then stopes. I can't tell if it is an issue with the wheel senser or the pump, but until I have it fixed I want to disable the ABS as I'd rather have non-ABS brakes then a moody ABS where I never know what to expect. I can't tell which is the main ABS fuse from the manual, so i'd be very grateful if someone points me in the right direction.
Thanks,
Bikebud.
