08-08-24, 04:01 PM
Afternoon chaps.
I've got a 2000 FZS600 and the 3rd cylinder simply refuses to fire.
What I've done so far is fresh spark plugs, some used but working OEM coils with caps, I've had the carbs off and cleaned all the jets (3rd carb was actually blocked so I thought I'd solved the problem but nope) a compression test (with throttle fully open) and all 4 cylinders are within a couple of PSI to each other at around 175 which from my research is perfectly healthy.
I've cleaned all the connections that I know of and have located from the battery all the way to the plug caps.
I've tried petrol down the cylinder just to see if it would fire at all.
I've tested the spark on cylinder 3 coil/plug and it's not the biggest and strongest spark I've ever seen but in my opinion it's strong enough to at least ignite the cylinder especially with a drop of fresh fuel.
The carbs are definitely getting fuel as is the cylinder because the carb bowls were all full after the rebuild and test.
I really can't think of anything else.
I don't really have the spare cash at the moment to put it into a garage but I'm also wanting to try and fix it myself to learn as I go.
The only thing I haven't changed is the battery and it is a bit on the dodgy side having been run dead previously but after a good charge it fires all the other cylinders within a second or two of pressing the button.
Is it possible that could be the culprit and it's only effecting a single coil wire/plug cap?
I'm really wanting to get back on the road as a friends just got back into biking as well as my Mrs wanting to go out for rides as pillion.
Any suggestions would be very appreciated.
