R6 Upgrade shock - looking for top bush
About 14 years ago I followed some advice on here and did the rear shock upgrade, with an R6 shock made in 2008. This has to be the strongest reason I still own the bike and exported it to Germany when I moved a few years later.
Fast forward to a few weeks ago I'm down the local TUV station (think MOT) and I escape by the skin of my teeth with a pass, with an advisory on the top bush of the shock. I've now removed the shock and extracted the knackered bush only to find no one seems to supply the dam things as replacements.
I notice Yamaha don't list this bush as an individual part (where as they did for the original Fazer shock) and Ohlins are no use at all (at least online).
Can anyone save the day by pointing me in the right direction of what will work here?
Hi,
I’ve had a Quick Look on Fowlers parts as below for a top bush for a 2005 R6 and you’re right, they don’t seem to list the top bush as a separate item, only the bottom.
https://www.fowlersparts.co.uk/parts/552...suspension
However, I recently had my Ohlins rear shock off and took it to MH Racing.
https://www.mhracing.com/
I had a similar issue, play in the top shock mount. Mark serviced it and fitted a new top bush for me. He’s an Ohlins service agent, so they are obtainable from Ohlins (for an Ohlins shock at least).
Not suggesting that you use Mark from where you are obviously, merely that they are available.
Hope you get sorted. ?
Supplies of the 2008-2016 shock are still plentiful, would it not be cheaper / less hassle just to replace the unit?
(17-06-24, 01:16 PM)kebab19 link Wrote:Supplies of the 2008-2016 shock are still plentiful, would it not be cheaper / less hassle just to replace the unit?
This crossed my mind, but how much can a 25mm long piece of rubber be? (Can press it in myself so no labour charges to consider) plus sometimes it is better the devil you know (I hope). Most the shocks I've seen the last couple of days are around the 100 quid mark with unknown history. This is at least option B if all else fails.
@SkidT
Thanks for the pointer, I've exchanged Emails with Mark this morning and I'm waiting further confirmation.  Smile
I'll keep a track of progress here when I know more.
Wow! almost 2 months off the road due to a small piece of rubber! But I'm finally back :-)
I'll cut a long story short, I finally managed to find something close enough from a German company. The part was listed but not in stock so I had to wait a few weeks before they did a production run. Yesterday I pushed the new bush in and along with a few spacers the shock was installed and road tested.
Thanks for the replies here, everything was part of the journey and I'm a little wiser now :-)
On a separate note, what size dog bones are required to fit the R6 shock to the fzs1000?
(08-08-24, 12:59 PM)RMT1983 Wrote: On a separate note, what size dog bones are required to fit the R6 shock to the fzs1000?
Didn't expect any questions here Big Grin
Just got on my hands and knees with a ruler to confirm what I thought: 130mm between the centers of the holes.
Ah then that's fortunate, that's what I've just ordered.. thank you!
