Unexpected Object?
Hi, I was wondering if any fellow foccer could tell me what this is please? It was in the storage space under the seat??? Thank you. Cheers.
it sits under the fuel tank vents on top of the rail near the fuel pump
Great! Thank you ?
I can't see how it could have made it's own way to the storage space under rear of seat though?
Tank breather rubber funnel.
Older bikes had rubber pipes coming from the tank metal pipes down to the lowest point of the frame with a breather pipe and excess fuel pipe.
Later models had this fitted instead so that the tank metal pipes just drop down straight into it, making things a bit neater and less chance of clogging up.
(29-05-24, 05:54 PM)arch33angel link Wrote: Great! Thank you ?
Very easy someone working on the bike took it off and put it there and forgot to put it back on.There is most likely a pipe sticking up where it goes on
