Gen 1 Exhaust header rear mounting bracket?
  ? I have noticed a number of mechanics doing M.O.Ts put a trolley jack under the collector box to get the front wheel off the ground to check the front wheel bearings, forks etc for play.  If this is a common practice it could be the reason so many of the rear collector box brackets fractures?  I always push the back of the seat down to allow these items to be checked. What do you think?
If at first you don't succeed, pull your foreskin ower yer heid!
How much of your weight do you have to use to push the tail down? That would be similar to the amount of weight resting on the collector box (allowing for leverage etc)
I'd have thought that failures would be more likely due to metal fatigue from the constant vibration.
@Dave, the brackets are at the lowest point on the bike, where they will catch all the crap coming off the road. Thus they will corrode and fail.
MY only issue with bikeshops doing that is have to make sure they dont scratch/scuff the underside of the headers.
  Pushing down on the rear of the seat to lift the front wheel up off the ground on the centre stand doesn’t put any load on the exhaust bracket.  Yes, they do catch all the crap and salt but I have seen some healthy ones broken, that simply need re-welded.
So my gen 1 fazer 1000 has broken its mounting bracket. Looks like rust has seen it off. Looking online doesn't yield any decent options for second hand ones- they look worse than the one i already have. Does a yone have any suggestions or ideas for header replacements?
