1998 fzs 600 coolant o rings
can the coolant o rings from the back of the cylinder head be replaced without removing the carbs as mines just pissed out the new antifreeze
If you're referring to the elbows that go into the cylinder head between the intakes?  It's not worth the effort and faff trying just pull the crabs back by removing the rear air box rubbers.
That way it's done right 1st go.
Later
yes thats the ones i mean, i was dreadding that to be the answer, ive managed to remove the allen bolt and can pull the elbow back just enough to maybe squeeze some instant gasket in i just bought from halfrauds, thanks for your help
(03-02-24, 06:35 PM)mechanical music link Wrote: yes thats the ones i mean, i was dreadding that to be the answer, ive managed to remove the allen bolt and can pull the elbow back just enough to maybe squeeze some instant gasket in i just bought from halfrauds, thanks for your help
That would be a selling fix botch job, do it right and do it once. Coolant is under a bit of pressure at that point and needs to be sealed properly
i agree, ive got the elbows removed now but cant find anything showing the correct size o rings so just going to take to a shop that sell viton o rings to try and match some new ones up if they have the size
(05-02-24, 01:30 PM)mechanical music link Wrote: i agree, ive got the elbows removed now but cant find anything showing the correct size o rings so just going to take to a shop that sell viton o rings to try and match some new ones up if they have the size
Just use the OE Orings: waterpump https://www.fowlersparts.co.uk/parts/416...water-pump  part 24 No 9321015566 £1.76 each, ignore it's 1999 drawing they are all the same.
Later
ive fitted viton o rings as they were recomended from an engineer years ago for something, hopefully they will do the job and got them for free too, cheers
OE are Nitron, hopefully you've got the correct size both ID,OD and thickness, they have a habit of picking non commercially available sizes.  You fit the non standard, they work for a while, then start leaking.  :rolleyes [size=78%]  [/size]
Later
