Hello
Changing the fork oil on a friends bike, as it hasn't been done for 10 years. So I am going to remove the forks,from the bike. Then I'm just going to let the oil drain with the forks upside down for a day or two. The springs just come out, don't they? As I don't fancy stripping the forks down. Then spary in some brake and clucth cleaner leave for a bit to evporate then maybe splash a bit of Isopropoly alcohol to clean the whole system out.
Or am I being stupid.
Hello, was there supposed to be a link leading else where?
11-01-24, 02:23 PM
(This post was last modified: 11-01-24, 02:25 PM by Grahamm.)
Weird, the link is in the post when I hit "modify", but it's not appearing.
ADDENDUM: Ok, I've just looked and it seems that video is no longer available!
Just search for "Dump and Run Fork Oil Change" and you should find what you're looking for.
12-01-24, 01:17 AM
(This post was last modified: 12-01-24, 05:07 PM by katana.)
Ah, the ducati fork one? Ah the is a cartridge fork
Thank you
12-01-24, 09:20 AM
(This post was last modified: 12-01-24, 10:26 AM by returning rider.)
see if that works
i found the Dave Moss videos on ergonomics very interesting, his analogy that you would never jump into a car with adjusting the driving position, yet we just jump onto bikes and expect our bodies to adapt was a very valid point and relatively simple steps to tailor the bike yo each rider.
hmmm same issue does not include the link in the message?
search you tube for Dave Moss or Dump & Run Motorcycle Fork Oil Change: NonAdjustable Damping Rod Telescopic & Upside down Forks
16-01-24, 07:36 AM
(This post was last modified: 16-01-24, 07:48 AM by darrsi.)
Make sure you get the oil level correct.
The forks without adjusters on the top take more oil than ones that do have them.
The air gap is the easier way to get the equal levels right on both sides.
I personally prefer 15W fork oil instead of the standard 10W, i found it a lot more stable.
98/99 models (without fork adjusters on top):
475cc oil 121mm air gap
00-03 models (with fork adjusters on top):
465cc oil 132mm air gap
My bike is a 2000 model but i swapped my forks with earlier model ones without the adjusters, so i have to remember to put the correct amount in each time.
