02-10-23, 12:41 AM
Hello,
The bike runs, but the idle is jumping a bit and it drinks oil a bit.
I did the compression cold and the PSI is about 100,150,150,160. After adding oil it went up to 170,180,180,190.
I'm thinking about changing the piston rings with the engine in the bike. Is that possible? If not I will have to remove the engine.
Could the piston rings fail just after 30k miles? Best place to get the piston rings just for one cylinder? A piston ring compressor would be useful, should I get 2 or 4?
I did rebuild the Honda 125cc engine, so I know the basics. Hopefully, the 4 cylinder won't be a pain in the ass.
Would I need some special socket the remove the engine bolts?
