05-07-23, 02:46 PM
Hi all!
I've got a poorly, misfiring, Fazer at the moment. Looking to do all the usual checks (plugs, caps, leads, coils, carb balance, etc). I'd also like to check the TPS but there is a problem... There is in aftermarket speedo/tacho unit on the bike which means I can't see any error codes, or any info from the TPS configuration mode.
Can the TPS setting become invalid after time? I took the carbs off, to give them a bit of a clean, but left the TPS on and didn't touch it. Assumed that it would be fine. The bike was working fine once, which means it was set correctly and hasn't been reset since. Is it likely that the TPS will need adjustment?
If so, can it be done with a multimeter? I've checked that the resistance is in range. And checked the varience in resistance when the throttle is open/closed. All is fine.
