Hey I decided to create a post summarizing my first restoration ever, on my fzs 600 98 my first bike.
Ive already dismantled it and went through virtually every part of the bike, only a few minor things have to be finished off. and I am trying to keep it as close to original as possible with only a new exhaust system, seat cover grips and levers and some hoses being the only visual differences. its still ongoing and I plan on updating this post until its completed.
Engine work
replaced the cam chain.
redone all valve clearances (13 were out of spec)
resprayed with heat resistant matt engine paint, valve cover white heat resistant paint.
carburetors cleaned out and rebuilt.
Frame and plastics
all plastics resprayed with VRC1 exact colour of red as original.
plastics also welded with hot staples and plastic bonder.
frame sprayed with black and 2k clear coat over.
steering stem bearings replaced with new roller bearings.
suspension
replaced the original shock with a low mileage used one. (might upgrade to yss in future)
front forks are working fine with no seal leaks. ( might upgrade forks or springs in future)
cooling system
replaced damaged radiator with good used one.
buying radiator guard soon.
new as3 performance red hose kit with stainless hose clamps.
wheels
sprayed black and clear coated with 2k
new metzeler m5 interact tires.
all wheel bearings and sprocket carrier bearing replaced and greased.
Engine work
Frame and plastics
suspension
cooling system
wheels
