23-06-23, 07:56 PM
why does the 3rd cylinder show low compression (70 psi) and the others are good (200-210 psi) on 2 different mk1 600 fzs engines all are cold readings as engines are not in bikes
cylinder 3 much lower compression
23-06-23, 07:56 PM
24-06-23, 09:23 AM
put a bit of oil in the cylinder to see if its a sticky/knackered ring.
Could be dirt/crap stopping one of the valves sealing properly too.
02-07-23, 09:40 PM
for me its cylinder 4 is really low, I suspect rings are worn but I wont bother replacing the pistons until winter
« Next Oldest | Next Newest »
