Oil drain bolt gasket
Hi all, I'm about to change the oil on my FZ1 ABS 2012 (my first time changing the oil). The manual says I should replace the engine oil drain bolt gasket with a new one, but there is no part number and I can find it on Fowlers. Can I just use a crush washer? and what is the size?
Thanks,Bikebud.
Id be surprised if its not the same as this https://www.wemoto.com/bikes/yamaha/fz1_...lly_washer
Halfords or any motor factors will have them. 17mm as far as I can remember. Commmon enough size most Japanese cars are the same size washers. Aluminium or Copper
Thanks, I'll order a set of various size washers and see what fits.
I have te original part number if you are interested
https://yambits.co.uk/fz1sa-fazer-abs-oi...37521.html
Yambits have the bolts/washers etc pretty cheap (about to do the same to mine)
https://www.amazon.co.uk/AUTOHAUX-20pcs-...219&sr=8-5
I'm using these at the moment which
but in the past I've used this type
https://www.amazon.co.uk/Connect-Worksho...179&sr=8-9
