Running low and high beam together. --Foxy--
Hello,
Is it possible to run low and high beam together when on High beam mode ?
When I ride on the side roads/country roads all I do is keep switching the lights from low to high all the time, because the roads are shit, with potholes and uneven roads all over the place.
Would pulling the wire from High beam light to low beam light work ?
I got LED lights, so they don't need so much power I would assume.
Thanks.
Wouldn't be kind on your battery, and wouldn't pass an MOT either.
Additional LED spotlights would be a better addition. Low down mounting should help with pot hole identification
Looks like will go for the LED spotlights. Any good ones on eBay ?
Single long one in the middle or two on each side ?
https://foc-u.co.uk/index.php?topic=21527.0
