14-08-22, 08:56 PM
		Hi peeps.
Anyone having noisy forks after a full strip & rebuild, all K-tech parts used, so should be ok for a good few miles.
Top bushes were a proper mare to fit, had to re-gap em to get em in.
Issue I'm having now is scraping noise on compression of forks, springs rubbing inside of stanchions.
Does anyone know of any stepped top hat bushes available to replace the washers on spring tops, this would keep the spring central & eliminate metal to metal contact of spring & stanchion.
