20-07-22, 05:06 AM
(This post was last modified: 20-07-22, 05:20 AM by CamSIXFIDDY.)
[size=1em]Hey peepz[/size]
[size=1em]Im replacing the oil, seals and bushings in the forks of my '02 1000, i have done seal replacements and rebuilds [/size]more times than I ever should have had too (wheelies can get expensive) with all my bikes over the years without many issues [shadow=red,left]UNTILL NOW![/shadow]
[size=1em]when putting the forks back together and driving the seals home, the outter/upper fork guide bushing[/size] is not going into its recess in the fork lower properly, which obviously stops me from setting the seal properly and installing the retaining clip. :wall Everything seems straight and square it just will not fit. The bushing was even put in the freezer the help with installation.
[size=1em]The bushes were ordered from brook suspention (NOX brand), far as im aware the parts are correct and are the new spec bushes that supersede yamahas original spec. [/size]
[size=1em]Lower/Inner/slide BUSHING[/size]
[size=1em]Thickness 1.00mm [/size]
[size=1em]Outer diameter 43.70mm[/size]
[size=1em]Inner diameter 41.70mm[/size]
[size=1em]Hight 20.00m[/size]
[size=1em]Upper/Outter/guide BUSHING[/size]
[size=1em]Thickness 2.00mm[/size]
[size=1em]Outter diameter 43.00mm[/size]
[size=1em]Inner diameter 47.00mm[/size]
[size=1em]Height 12.00mm[/size]
[size=1em]Anyone had an issue with these sizes or brand. [/size]
"Reckless? Fuck You That Was Awesome"
