19-02-22, 02:22 PM
(This post was last modified: 19-02-22, 02:28 PM by CountFazer.)
Hi all,
I've been getting stuck into a valve clearance check and reshimming. It's nearly all done but I'm having a couple of issues with reassembly and timing.
First, the front cam chain guide. Can this be inserted/removed with the camshafts already bolted down? In the Haynes manual the guide goes in after the camshafts are secured, and before the cam chain tensioner is put in. But, I cannot for the life of me work out a way to fit it in without removing the exhaust camshaft to make some space.
Second, valve timing. My timing looks slightly out at the moment, especially looking at the intake timing. I've attached some photos of the datum - maybe the timing is fine, so I just want to hear some thoughts on it.
https://imgur.com/zx1WMDR
https://imgur.com/2KcCVsV
https://imgur.com/GuLgj0f
Also, will putting the front guide in alter the location of the timing datum? Just trying to work out if I should factor this in when correcting timing.
Cheers
Cheers
