02-01-22, 09:22 AM
Hello fitted k tech linear springs but not sure of oil capacity and air gap any help thanks in advance
K tech springs
02-01-22, 09:22 AM
I'm making the assumption this is for a Gen1, as you don't state this.
The Yamaha service manual is available to download from the Downloads section. Each leg should have 440ml of fork oil, the air gap should be 140mm measured from the top of the inner tube and damper rod, with the tube fully compressed and without the spring. K-Tech advised me that this would be the same with their springs as with the OEM.
02-01-22, 04:18 PM
Thank you that's what I though
« Next Oldest | Next Newest »
