Can anyone tell me bolt and nut sizes for the wishbones are? because both my local dealer/s and Fowlers don't know or cant tell me.
FZ1 rear suspension: Linkage parts
06-12-21, 04:06 PM
Off the top of my head M10 course with 14mm bolt head, nuts will also be 14mm nut. The nuts will more than likely have a lower flange to them, as will possibly the bolt head.
Later
06-12-21, 05:19 PM
06-12-21, 06:30 PM
(This post was last modified: 07-12-21, 09:40 AM by Decoke Dave.)
Yes. All the M10 bolts (and M12 for that matter) are 1.25mm pitch on our bikes. You should use the same tensile strength of bolt. This is marked on the bolt head but the Japanese designate this differently from Europe! Just to complicate matters! ?
If at first you don't succeed, pull your foreskin ower yer heid!
09-12-21, 10:05 AM
(This post was last modified: 09-12-21, 10:07 AM by Dudeofrude.)
Any idea on the part numbers for those? As I've still got some used genuine nut and bolt sat here that I'm certain we're from when I swapped my linkages out. part numbers 90105-10323, 95607-10200 and 90105-10030. They're used but have been resealed in the bag
09-12-21, 10:06 AM
(09-12-21, 10:05 AM)Dudeofrude link Wrote: Any idea on the part numbers for those? As I've still got used genuine nuts and bolts sat here that I'm certain we're from when I swapped my linkages out. part numbers 90105-10323, 95607-10200 and 90105-10030. They're used but have been resealed in the bag |
« Next Oldest | Next Newest »
