so is it possible to fit mk2 clocks to the MK16, fzs 600? Or is it more chew than it’s worth?
					Mk2 clocks on MK1 fzs600?
		24-09-21, 09:35 AM
		Someone will correct me but I believe the answer is yes, and that it should be a straight swap.
		24-09-21, 11:20 AM
	(23-09-21, 11:38 PM)StreetFzr link Wrote: so is it possible to fit mk2 clocks to the MK16, fzs 600? Or is it more chew than it’s worth? Assuming you mean the 2002/3 FZS600 clocks on an 98/99 FZS600 then yes, as Gnasher says, they will fit (and work) with a change to teh connector plug. If you mean FZ6 clocks on an FZS600 - no they wont work or fit.
		24-09-21, 11:41 AM
	(24-09-21, 11:20 AM)BBROWN1664 link Wrote: If you mean FZ6 clocks on an FZS600 - no they wont work or fit. :thumbup
Later
		24-09-21, 11:15 PM
		Thanks lads, I did mean the later fzs600 clocks on the earlier fzs600!
Much appreciated!!! 8)  |
					« Next Oldest | Next Newest »
