Renthal 758
Many recommend Renthal 758 as an improvement on the Gen 1 Fazer 1000...can anyone advise ? are they lower or higher than standard ? Thank you.
They are about the same height as the originals but a little straighter i.e. not as swept back. The original bar end weights do not fit the Renthals and you will have to drill a hole for the switch gear locating pin. They are good though once you get used to them. Big Grin
Get a thread tapped in the end of the Renthals, 16mm at 16 t.p.i, to fit the original bar end weights, which are quite heavy (308 grams) and do a good job.
Thanks for the replies.
The Sweep / pullback of the 758 bars feels comfier (to me).  I also tapped mine out & fitted heavier FJ1200 bar ends to minimise the vibes.
I tapped the end of mine and fitted the original bar ends
