FZS600 fork issue
hi all just fitting a new speedo drive to my bike its a 1999 fzs600 if it makes a differance, and there are no thread in nearside fork leg, so axle is just being held by pinch bolt, this cant be correct can it? just passed mot like this too! :'(
(10-08-21, 02:38 PM)stles link Wrote: hi all just fitting a new speedo drive to my bike its a 1999 fzs600 if it makes a differance, and there are no thread in nearside fork leg, so axle is just being held by pinch bolt, this cant be correct can it? just passed mot like this too!:'(
Nope, the main axle/bolt should be threaded on one end, done up to 67Nm, the pinch bolt is a locking method.  The MOT would just look for loose or obviously worn bolts/nuts, as loong the there was no play and the axle was fully seated it would pass an MOT.
You either get the lower leg rethreaded or replace it.
Later
thanx, replacment forks on way for it Smile
