Hi all, new to FZS1000s bought one recently very please with it, goes well got the 7k tacho so checked the exup valve it's seized solid and the pulley is rusty as old nail the prongs fell off when I touched them so no maintenance I suspect, if I remove it what will happen will it notice thanks 8
Hi matey & welcome to the madness.
Exup''s are often seized in some way, finding a good used unit that's serviceable is like trying to find Unicorn shit.
Never seen one for sale, occasionally half decent set of headers appears on eBay but usually seller wants silly money.
Most pipes never have a valve in em.
It's no big deal to leave Exup out, if you ride in lower to mid RPM range, you'll notice it till you adapt to it, if you cane it everywhere, it'll not be missed.
If you decide to remove it, just disconnect Exup cables from servo motor, leave servo plugged in, if servo''s not seized, youl'll not get tacho fault code.
If the valve is seized in the bushes/housing, removing it might involve almost as much effort as getting it functioning again. Finding a replacement pulley is much easier than finding an entire working EXUP.
It would be worth trying to get it working again. Maybe remove valve temporarily, refit the end plate with a bolt/washer to blank the spindle hole and focus on getting the valve and bushes separated then refit when they're free-spinning as they should be.
16-06-21, 09:27 PM
(This post was last modified: 17-06-21, 04:40 PM by Decoke Dave.)
(14-06-21, 04:40 PM)TonupSid link Wrote: Hi all, new to FZS1000s bought one recently very please with it, goes well got the 7k tacho so checked the exup valve it's seized solid and the pulley is rusty as old nail the prongs fell off when I touched them so no maintenance I suspect, if I remove it what will happen will it notice thanks 8
Things could be worse! Spare a thought for this poor guy! In the search facility at the top of the page search"removing the downpipes". Where it says under username put in *solorider* it doesn't get much worse than this! Do not know if he is still an FZS 1000 owner or if the whole affair broke him! :'( No wonder!
If at first you don't succeed, pull your foreskin ower yer heid!
