08-06-21, 10:09 PM
Has anyone owned their FZS 1000 from new?
If at first you don't succeed, pull your foreskin ower yer heid!
Owned from new?
08-06-21, 10:09 PM
10-06-21, 10:12 AM
Not from new, mine was 18 months old with 4K up.
10-06-21, 04:26 PM
again not new, but 2 years old with 3K now at 88K
10-06-21, 05:52 PM
Yes owned mine from new & payed £5500 including datatool S4 red alarm & picked up on 1st March 2006 so its on a 2006 plate & its running K-tech front folk springs & a re-valve kit plus a R6 shock on the rear & never had any trouble with it apart from a vibration problem with around 25000 miles on it that was only cured after i re -torqued all the engine bolts 3 times to Yamahas specification using 2 difference torque wrenches but ended up just doing all the engine bolts up with a 3/8 ratchet quite loose by hand & its been quite smooth for 10 years now but still have no idea why i had the vibration in the first place but only checked the engine bolts after putting a genuine new Yamaha chain & sprockets set on at around 25000 miles with only a very slight improvement in the vibrations but i certainly not recommending anybody else leaves there engine bolts under Yamaha torque setting but it worked for me,stay safe everyone,cheers Steve
12-06-21, 10:46 PM
I bought my FZS1000 brand new and had it delivered on the 1st of December 2001, but I didn't use it till the following April. I intended to keep it for 2 years but 20 years and 173,000 miles later, I still have it. I have 4 other bikes and mainly use the Fazer for Winter rides. I have serviced it myself from new, very little has gone wrong with it, apart from a couple of neutral switches, oh and crashing it 3 times [and fitting a 1200 Bandit fairing] It is still on the original clutch, wheel bearings and suspension, although the damping is well tired now. The only thing I dislike is the reluctance to select neutral occasionally in really hot weather, no problem in winter! For me it's probably the best bike I've owned, and there's been a lot!
13-06-21, 05:11 AM
173k..... Kudos to both you and the machine
09-07-21, 08:48 PM
Owned mine from new since 2002.
Never missed a beat and sitting on 10k miles now. (Hangs head in shame lol) All the best. Dave
23-07-21, 10:35 PM
Hi,
I’ve owned mine from new June 2002, Changed a few things over the years , Just fitted R1 front forks. Fitted an R6 rear shock. Ivan’s kit. Ignition advancer. Just gave the old girl a new paint job Yellow and black speed block . |
« Next Oldest | Next Newest »
