01-06-21, 08:00 PM
Can anyone tell me exactly what the original toolkit should contain?
If at first you don't succeed, pull your foreskin ower yer heid!
FZS 1000 original toolkit?
01-06-21, 08:00 PM
From memory -
Spanners: 1x - open dual end 8/10mm 1x - open dual end 12/14mm 1x - C-spanner for reach shock. 1x - Rear ring spanner for rear axel nut (not sure on the size) 1x - single end 17mm ring single 1x - dual size spark-plug box spanner. Screwdriver: 1x medium phillips/flat head screwdriver bit 1x large phillips bit Misc: 1x Allen key (M6 I think) 1x extension tube for Ring/C-spanner. 1x Adjustable pliers I added the following items to my took kit - 1x each of thew small allen keys - needed to get all the front fairing/infill bolts off when required. 1x oxford socket adapter for the front axel - https://www.machinemart.co.uk/p/oxford-o...removal-t/ 1x mechanical tyre pressure gauge (looks like a pen) 1x Oxford emergency clutch/brake cable kit - http://www.denniswinter.com/off-road-c1/...it-p188920 Then in a second bag: 1x gremlin puncture repair kit - https://www.sportsbikeshop.co.uk/motorcy...rod/101778 And in summary I was able to get both toolkits and a disclock behind the back seat with space to spare. |
« Next Oldest | Next Newest »
