Main fuse blowing
Hi riding home last night lost all electrical power,found main fuse blown and when replaced blows again with ignition off.
I have checked for bad wiring (rubbing wire) but all looks OK,pulled plug off regulator and fuse OK put regulator back fuse blows so think bad regulator, any body had this before any suggestions before I buy new regulator thanks.
Does the fuse blow with the engine off or when its running?
Could be a bad regulator or a bad charging circuit. I would get a meter on the wires from the regulator to check for an earth where there shouldnt be one.
Hi engine not running key in off position thanks
If anybody is interested the reason main fuse blowing,was a bad regulator 1 diode had gone bad
