R6 5 spokes wheels on fazer 1000
hi guys
i have just got hold of a really nice set of 5sl wheels 5 spoke , any one done this swap , front looks like it will go straight in , the back looks ok but will need a spacer on the brake side
any one help on this
thansk
mike
I've done it, need more than just a spacer for the rear brake side, I used a FZ1 ABS Caliper mount and caliper modified to use the Gen 1 torque arm.
you will also need the Front R6 or R1 Discs (5 Bolt) .
THe sprocket side you can use the Fazer carrier and spacers.
See Photos for images of the rear wheel brake side modified caliper bracket and spacer.
I did it this way as the mod is reversible, using R6 or FZ1 caliper carriers needs you to weld a block to the swinging arm.
For reference I used a set of 2003 R6 wheels, don't know the vehicle code.
[size=78%] [/size]
Looks like the photos were too large for one post.
[Image: MGalleryItem.php?id=3468]
[Image: MGalleryItem.php?id=3463]
Verra Noice, can we see shots of the whole bike with the 5 spokes...?
(16-04-21, 10:33 PM)b1k3rdude link Wrote: Verra Noice, can we see shots of the whole bike with the 5 spokes...?
Not the best photo but the best one to hand. Will get a better one over the weekend.
[Image: MGalleryItem.php?id=3506]
Looks nice, hope you didn't scuff the back end against the wall/pipe.
many thanks red , i am picking up another fazer on monday so the old one will be in the workshop untill i sell it on , so i'll have a lot more time to play with it . i have the disks and new ti bolts for the front and back so will need to look at the surport arm , spacer,and caliper from what i can see in your photos , is there any others wheels maybe a gen 2 rear ??
many thanks
I'd not looked at other Yamaha bikes as I wanted to keep the same wheel geometry (rim width & tyre size) as I had heard that going to a R1 wheel with a 190 tyre has a minor negative effect on the bikes steering, plus you can swap existing tyres from current Fazer wheels.
I don't think there would be much in it between using R6 and FZ1 wheels and the modifications you would need to do to fit them to the fazer as things like sprocket carriers look fairly similar, pity there arn't old style breakers that you could sometimes go and measure and try parts next to each other.
Not too worried about scuffing the fazer she's a user, not a trailer queen and already has already a few marks gained in the 59K miles and 18 years she's done.
thanks red stay safe
