Help with spring change
I am struggling to change the fork springs on my FZS 600 02 model. When I unscrew the endcap it does not come away from the slider and consequently cannot be removed. Any advice much appreciated.
Not undone it all the way?
Have you loosened the top clamp as that normally prevents you from undoing the top cap.
When I pull the endcap out the slider and spring want to come with that but will not
sounds like someone has assembled it incorrectly
Any suggestions?
The only one I have is to pull harder. If the spring etc have become jammed, the one lay to separate them is with force.
Will have a go next weekend as need bike this week
