21-03-21, 10:01 PM
		Hi all, hope you're all getting back on the road ok. I was out earlier today and had a very unexpected lockup while setting off onto a roundabout, it felt like both sets of brakes snatching on then releasing though I had no tyre skid, it also felt, worryingly, like a transmission lockup and I'd say that would be a more accurate description, the front didn't dive like it would if the front brake suddenly locked on, I was in 1st and only doing maybe 10mph. I was a bit confused, a few miles later, heading home after a visit to a shop, it happened again, this time at about 30mph and was a sudden jerk/shudder, I pulled the clutch and released it, carried on till I could pull over and check the bike, all seemed ok, happened a third time and I limped home at 30, not wanting to go faster and it did the 10 miles home ok. Not long had new tyres, fitted the wheels myself and done this every time I've had rubber fitted over the 10 years I've had the bike, so I know there is no issue there, I double checked anyway. I had the front sproket cover off having previously had the front sproket nut decide that it didn't want to stick around any more and is in some French field near Saint Quentin, no problem there, the upgraded nut is still in place and tight. Chain tension is fine, having not long fitted the rear wheel on (100 miles ago) I put the bike on the centre stand and had it running and in gear, tried 1st, 2nd and 3rd, no problems, some slight rear chain lash, but nothing I wasn't expecting. Any thoughts on this as I am totally stumped, been riding since I was 16, 52 now and not seen anything like this.
