Nice little upgrade
Just overhauled he rear end with new swing arm and shock linkage bearings, pins and seals. Decided to upgrade the shock while I was at it.... R6 shock has gone into the spares box for now.
[Image: Cm3YN9Nh.jpg]
[Image: ILZULvph.jpg]
[Image: RhQ8hvIh.jpg]
[Image: kR94wKQh.jpg]
[Image: 31gIr5ah.jpg]
[Image: HW9TRxfh.jpg]
[Image: PbQ8Anch.jpg]
FZS 1000 Gen1 (2003)
Tiger 900 GT Pro (2020)
Nitron  shocks are the badgers nadgers.
One question though, is it just the camera angle or is that nut securing the shock to the linkage a little closer to the link arms?
(\__/) This is bunny. Copy and paste
(x'.'x) bunny onto your page to help
(")-(") him gain world domination!
(20-03-21, 01:42 PM)celticbiker link Wrote: Nitron  shocks are the badgers nadgers.
Yes, it is quite close but doesn't snag. The shock came with free fitting and set-up so I didn't fit it myself. Apparently it comes with a new bottom bolt in the kit. Was tempted to refit the original bolt, but cant see it being a problem because there is no lateral movement at that point so don't think the clearance is that critical.
Looks very nice. Significantly [size=78%]cheaper than an Ohlins equivalent? Which model did you go for? [/size]
Looks like real tidy bike you’ve got there. :thumbup
(20-03-21, 03:09 PM)SkidT link Wrote: Looks very nice. Significantly [size=78%]cheaper than an Ohlins equivalent? Which model did you go for? [/size]
Went for the R2 model .... NTBKY09T
I'm surprised no-one else has commented on the complete absence of oil, grease, dirt or other crap on any single component of the bike in those photos.
Seriously, when was the last time you saw the underside of a Fazer look that clean unless it was sitting new on the showroom floor? Big Grin
(20-03-21, 10:34 PM)Falcon 269 link Wrote: I'm surprised no-one else has commented on the complete absence of oil, grease, dirt or other crap on any single component of the bike in those photos.
Everything got a good clean when I took the swing arm off. Hate working on greasy filthy components.
Hi just wondering what spring rate you ended up with based on your rider weight and if you have set up your sag settings, what pre load did you end up with to get them?
I just fitted an R1 and still having issues over the spring rate they recommended, also the video on there website changing the spring yourself is wrong, [size=78%]it can’t be done on this model anyway.[/size]
Hi where did you get the alloy swingarm bungs/caps from,cheers
Ooh oooooh .... so very nice. I have Nitron on my Tiger Sport.
I am very tempted to do the same for the Fazer ... enjoy. Have you had the forks modified at all.
P.S very clean too ... Royal Navy standard cleaning there! Top man  Big Grin
(21-03-21, 11:10 AM)Capt link Wrote: Hi just wondering what spring rate you ended up with based on your rider weight and if you have set up your sag settings, what pre load did you end up with to get them?
According to the service sheet the spring rate is 525lb. Rider weight with kit is 84kg, pillion weight with kit 54kg.
My local supplier fitted the shock and did all the set-up for me ..... http://www.tyres4bikes.co.uk
(21-03-21, 11:58 AM)easym5 link Wrote: Hi where did you get the alloy swingarm bungs/caps from,cheers
Ebay - from a breaker.
(21-03-21, 04:09 PM)Timbo link Wrote: [size=1em]Ooh oooooh .... so very nice. I have Nitron on my Tiger Sport.I am very tempted to do the same for the Fazer ... enjoy. Have you had the forks modified at all.P.S very clean too ... Royal Navy standard cleaning there! Top man  Big Grin [/size]
[size=1em]I overhauled the forks in the winter. New seals, bushes, oil and Hyperpro progressive springs.[/size]
Standard dog-bones or modified?
(21-03-21, 05:49 PM)teecee90 link Wrote: [quote author=Capt link=topic=26781.msg323945#msg323945 date=1616321434]
How can the local dealer 'set up' the the rear shock for you?
He doesn't know your
Front rear weight balance preference
Braking technique
Weight transfer speed/control preference under braking and acceleration
Did he ask about your tyre choices ( stiffer or softer side wall)
Indeed did he ask you anything?
Shock set up is not a game, your life can depend on it!
You can lose the front under braking if the rebound is wrong or under acceleration if the compression is wrong.
There are a million ways it can go wrong when you trust someone else with the set up.
If he isn't YOUR mechanic and he hasn't spent hundreds of hours working and talking to you he can't know how to set up your shock only you can do it correctly.
(21-03-21, 10:10 PM)celticbiker link Wrote: [quote author=teecee90 link=topic=26781.msg323957#msg323957 date=1616345388]
Braking technique
He asked lots of questions, took lots of measurements, sent me on test runs and asked questions after each run. All I can tell you is that it worked a treat for me.... handles great now.
In that case absolutely well done that man.
Don't find many that go to that trouble and as you didn't mention it I thought I would.
Keep an eye on the tyre wear though, one or two clicks more or less on compression make the difference between squaring off the rear or keeping its profile.
(21-03-21, 07:03 PM)Timbo link Wrote: Standard dog-bones or modified?
Lowering dog bones (I'm a short arse). I had standard bones on with the R6 shock but needed to put the lowering (longer) ones back on for the Nitron as it isn't one of the adjustable ones. The R6 shock is shorter than the stock shock so standard bones worked fine.
Decided to change the bottom bolt after all. Plenty of clearance now. Better safe than sorry....
[Image: PFkEJvhl.jpg]
[Image: fAgAAPil.jpg]
[Image: avqk9Unl.jpg]
Keeps you awake at night doesn't it?
