Starter Relay Fuse
I just had a new starter relay turn up and it has a 10amp fuse in it, but "most" photos I see online have 30amp fuses on them.
I've not had a chance to look at my old unit yet as I'm a bit busy, but which fuse d'ya think I should use, as my Haynes Manual doesn't actually specify a size?
From memory, the main fuse is 30A, the relay has 2 30A fuses one is a spare.
Later
Yeah, most pictures have the green 30amp fuse in, but for some reason this has turned up with the red 10amp ones in.
If my old ones are 30amp I'll swap them both over.
Thanks Gnasher
.png   Capture.PNG (Size: 1.01 MB / Downloads: 7)
