03-02-21, 06:42 PM
All parts available from eBay store.
> All items open to offers
(04-09) FZ6:
- rear wheel cush drive rubbers
- rear brake caliper and pads
- rear brake caliper bracket
- rear brake pad retaining shim (small metal one that fits onto bracket)
- rear brake light
- coolant overflow bottle
- battery box
- seat latch
- bar end weights
- main stand spring
- coolant cap
- various rubber heat shields / brackets
- small bolt job-lots (split due to overall weight)
(98-03) FZS 600
- rear brake light housing
- choke cables
- throttle cables
- right pillion footpeg
- rear shock absorber
- CDI ECU Unit
- rear middle fairing cover piece (black)
- thermostat housing (pins on sensor plugs are slightly bent, un-tested)
- Top yoke with ignition barrel (x1 key)
- bottom yoke
