MOT rule changes January 2021
Be warned - both HID and LED bulbs are now an MOT failure
Updates - MOT inspection manual: motorcycles - Guidance - GOV.UK
[color=rgb(11, 12, 12)] changed from 'Some motorcycles may be fitted with high intensity discharge (HID) headlamps. Existing halogen headlamp units should not be converted to be used with HID bulbs. If such a conversion has been done, you must fail the headlamp.' to 'Some motorcycles may be fitted with high intensity discharge (HID) or light emitting diode (LED) headlamps. Existing halogen headlamp units should not be converted to be used with HID or LED bulbs. If such a conversion has been done, you must fail the headlamp.[/color]
[edit] removed my duplicates and cleaned up the url link above
