I purchased a modified Fazer back in September and the previous owner put flatter bars on it. The front break master cylinder reservoir is not parallel with the brake lever. This means that now, when the bike is upright, the reservoir is sloped at an angle and not parallel with the floor.
I found out the problem with this the hard way. I went to drain the brake fluid while fitting new brake hoses. Took the cap off the reservoir and got covered in brake fluid. When replacing the fluid I had to lean the bike over to make sure I could put enough in without any spilling out.
Has anyone changed to flat bars? If so, did you do anything to make the reservoir level with the floor when the bike is upright? Maybe replace it with a different one from another bike? Or are you just careful when replacing fluid and bleeding your brakes?
![[Image: tXBD3rr.jpg?2]](https://i.imgur.com/tXBD3rr.jpg?2)
![[Image: YydTfha.jpg?2]](https://i.imgur.com/YydTfha.jpg?2)
![[Image: 56Rn0Bn.jpg?1]](https://i.imgur.com/56Rn0Bn.jpg?1)
