Bench sync yamaha fazer 600 carbs(2003 Model)
Hi
I have a yamaha fazer fzs 600(2003) i have removed stripped and cleaned my carbs. I have read the you can bench sync your carb to get them into the rough ball park before being more precise when fitted to the bike. The information I'm looking for relates to the base carb, I'm :'( [size=78%] at a loss as to which on is the base carb, any help would be fantastic.[/size]
When on the bike, #1 is synced with #2, #3 with #4 and then #3 with #2. I would say #2
(09-12-20, 02:13 PM)BBROWN1664 link Wrote: When on the bike, #1 is synced with #2, #3 with #4 and then #3 with #2. I would say #2
So at a guess you would say No2 is the bench Carb?
(09-12-20, 02:58 PM)neilr link Wrote: [quote author=BBROWN1664 link=topic=26646.msg321974#msg321974 date=1607519585]
Tells you how in the service manual. Download from the Downloads Section on the toolbar
See Pic
.jpg   fazer 600 base carb.jpg (Size: 79.6 KB / Downloads: 59)
:agree - If thats what the manual says then it is #3 not #2
(09-12-20, 04:17 PM)BBROWN1664 link Wrote: :agree - If thats what the manual says then it is #3 not #2
Thanks everyone for your help ill try that setup! Smile
(09-12-20, 06:18 PM)neilr link Wrote: [quote author=BBROWN1664 link=topic=26646.msg321979#msg321979 date=1607527026]
[/quote]sorry for asking a silly question but here goes, carb 3 is sync with 4, then carbs 1 and 2 then 2 and 3? is that right?
yes. There are screws between 1&2 to balance them, between 3&4 to balance them and then 2&3. If #3 is the base then start getting 3&4 then 1&2 and finally 2&3
(09-12-20, 06:39 PM)BBROWN1664 link Wrote: yes. There are screws between 1&2 to balance them, between 3&4 to balance them and then 2&3. If #3 is the base then start getting 3&4 then 1&2 and finally 2&3
Thanks again but i had to ask Wink
Pic
